Design upgrade
A project log for Kobold - retro TTL computer
A 16 bit computer with 20 address bits and video display, from just a few TTL and memory chips. Instructions resemble 68000 / PDP-11.
roelhroelh 04/18/2019 at 11:271 Comment
The current design of the microcode structure is almost complete, with just a few loose ends that have to be solved.
However, the total design effort for the project will be quite huge, and it would be a pity if the result is inferior on certain aspects. It seems that with a little more effort, a better result can be obtained (at the cost of a few more components).
This will focus on two main aspects:
So, work to do !
Yann Guidon / YGDES wrote 04/19/2019 at 03:33 point
It's getting even more interesting :-D
