Basic Specs of SIMPP.
Microcontroller: PIC16F877A 8bit microcontroller
Clock: 4Mhz
GPIO: 30 (external) + 1 (internal)
Digital IO: 30
Analog Input: 5 (multiplex to Digital IO)
Power Supply: 9-12V, 1amp (External) or USB
Computer Interface: USB
Programming Language: C Programming
Board Size: 2.6×2 inch
PCB Fabrication: refer to link https://jlcpcb.com/m
Software
The SIMPP utilize the MPLAB IDE and programming in C language. In-order for the C programming to be compiled in MPLAB, another software name PICC is also needed to be installed for the C programming be compiled in the MPLAB. The MPLAB and PICC software’s are downloadable from the internet. A programming structure and functional libraries was created for the development of projects. This will help the programming simple and easy.
Difference of SIMPP from Other Platform
1. High GPIO Count with small board footprint
2. Can act as Development and a Programmer platform.
3. Utilize the microcontroller manufacturer IDE that is user friendly and support multiple microcontrollers.
4. Utilize the manufacturer programmer (pickit2-modified for simpp) which will easily connect to other microcontroller (using ICSP) and this will not requires a microcontroller with bootloaders.
5. No USB Driver/patch or dll needed to be installed for PC communication. Just Plug, Connect and Play.
6. Programming can be done even with an external power is connected.
7. Simple and Flexible programing structure
arnie.omallao
John Rampelt
Stefan Wagner
Manuel Bl.
Ella Jameson
firmware for pickit2 is still available (during fabrication) and thus the mplab version. it can still be used for simple and major electronic project. it can even be use to prototype machines. not all project you need to use pic32 and pic8 is still being produce.
