Back From the Fab and Assembled
A project log for OPEN Power (Prototype 1)
I didn't have enough to buy a Lab Bench PSU... So I made one.
John LoefflerJohn Loeffler 05/24/2019 at 21:010 Comments
I got the boards back from the Fab but... I made a little mistake with Power and Ground.  I made 3 of these boards and they kept failing.  Turns out if you use 5v for ground and ground for 5v thing don't work that great.  I did a fire rout and the board works fine.
