OPEN Power
I didn't have enough to buy a Lab Bench PSU... So I made one.
Public Chat
Open Power is about providing Makers, Students, and Hobbyist with a Portable, Versatile Intuitive and Cheap power supply for all their projects.
Prototype 1: Simple and Cheap Constant Voltage/ Constant Current Power Supply variable from 0.6V to 12V with led voltage indication. USB Load sharing powered and Lipo backup. (cost under $3.00)
Prototype 2: A Constant Voltage Constant Current Power Supply 0.6V to 12V In addition to an adjustable Negative Rail. Voltage and current Monitoring Provided by a OLED Display.
Prototype 3: LDO's to Reduce the voltage between 0 and 12V. Both +- Rail Voltage Current and Power will Be displayed on a Full Color LED Display, and oscilloscope/Logic analyzer
The goal of Open Power is not to replace the desktop power supply or oscilloscope but to provide an entry level experience for all.'
We are Committed to keeping OPEN Power Open Source and will release all design file once tested for reliability and safety.
The goals of OPEN Power is to produce 3 final Prototypes. All Power Supplies will have USB Charging of Lithium polymer batteries and a Load Sharing and Uninterruptible power when disconnected.
Prototype 1A:
Simple Constant voltage
Power SupplyVariable from
0.6V to 12V.
Will Include 5V and 3V Rails.
Voltage indicator will be
achieved using comparators and
LED Array.
This was chosen to reduce
cost as much as possible and
keep each board with
components under $2.75.
Status
(COMPLETED)
    BOM (LINK)
Schematic (LINK)
Gerber Files (LINK)
Prototype 1a: Rendering
Prototype 1a: Assembled
Voltage Test
Voltage Test
Load Sharing and Quick disconnect Test
Load Sharing / Uninterruptible Test
Prototype 1B:
Revision 1B The Led arrays are switch
from a linear array to a polar array
around the Voltage and Potentiometer
trimmers have been added to calibrate.
Status
(COMPLETED)
      BOM (LINK)
Schematic (LINK)
Gerber Files (LINK)
Prototype 1B: Rendering
Prototype 1B: Asseembled
Prototype 1C:
Revision 1c will add an additional  Constant Current Knob to allot
user to limit current and see
around what current is being
drawn (10mA Increments).
Status
(Sent to FAB)
       BOM (LINK)
 Schematic (LINK)
 Gerber Files (LINK)
Digikey BOM (10 units)
Prototype 1C: Rendering
Prototype 1C: Routing
Prototype 1C: Inside and out
Prototype 2A:
A Constant Voltage Constant current
Power Supply 0.6V to 12V.
Rail.  Voltage, Current and Power of
thepositive Rail will be displayed on a
compact OLED. Negative Rail Voltage
will also Be displayed as well as the
Battery Voltage.
Status
(Layout Mock-up)
Prototype 2A: Rendering
Prototype 3A:
Utilizes a Boost Inverting IC to get
+-13V and LDO's to Reduce the
Voltage between 0 and 12V.
Both +- Rail  Voltage, Current and
Color 0.96" LED  Display.
Status
(COMPLETED)
      (Some Errors See  Schematic)
        Schematic (LINK)
       Gerber Files (LINK)
            Code (LINK)
Prototype 3A - Render
Prototype 3A: Rendering
Prototype 3A: Assembled
Prototype 3A: Load sharing Test
Prototype 3A: Constant Current Test
Prototype 3B:
Revision 3b will have a DAC Output,
2 Analog input and 4 DIO Pins.
The implementation of a 16-Bit ADC
Will improve the Current Readout
Status
(Sent To the Fab 8/28/2019)
Update - design Errors made and sent
 back to the fab
             Schematic (Link)
Prototype 3B: Rendering
Prototype 3B: Layout
Prototype 3C:
Revision 3c will switch from the
Samd21 to the Samd51 for faster
Processing power and additional IOs.
The LCD will also be upgraded to a
1.3" IPS 240x240 LCD. Since the
circuit is completely analog the MCU
can perform Double duty and
Potentially be used as a Crude
Oscilloscope or Logic Analyzer.
Prototype 3C: Layout Mock-up
Zip Archive - 344.93 kB - 03/29/2020 at 22:13
Download
Zip Archive - 288.02 kB - 03/29/2020 at 22:13
Download
Open Power - Hackaday Prize -720.mp4
Hackaday Prize - Backup Video Submission
MPEG-4 Video - 46.63 MB - 10/01/2019 at 06:24
Download
Open Power - Prototype 3A.zip
Open Power - Prototype 3A - Gerber
Zip Archive - 93.28 kB - 09/25/2019 at 21:34
Download
Open Power - Comparison.pdf
Open Power - Product Line Comparison Vs Competition
Adobe Portable Document Format - 7.11 MB - 09/24/2019 at 00:00
Preview
Download
View all 15 files
  • 2 × MT3608 Boost Converter Modified to be a Sepic Boost.
  • 1 × MIC5225-5.0 5V LDO
  • 2 × LED - 0603 - Yellow LED - 0603 - Yellow
  • 2 × LED - 0603 - Orange LED - 0603 - Orange
  • 3 × LED - 0603 - Red LED - 0603 - Red
View all 45 components
View all 18 project logs
  • 1
    Hackaday Prize Q and A
    i. Is this a unique solution to a particular challenge facing the world today?
    Power Supply and Oscilloscopes are an Invaluable pieces of equipment for Engineers, Hobbyist, and Student.  It allows them to test their circuits under a variety of voltage and current conditions.  The problem is the are bulky, stationary, and expensive.  With release of these cheap Battery power supplies that attach to the breadboards users can make their projects mobile.
    The goal of Open Power is to take it a few steps further.  To integrate Lithium Rechargeable batteries. Quick Disconnect and a Variable Rail (0.6V -12V).  With Iterations capable of Constant Current, Current Monitoring, Digital I/O indicators, Voltage Reads, Crude Oscilloscope and Logic Analyzers.
    All These features with an aim at keeping cost as low as possible.  With our cheapest unit (Less than $2.50 Cost) multiple units can be Purchased and used in multiple projects.  This solves the problem of having to disconnect the circuit from the power supply to start a new project.
    Open Power will NOT replace the bench top power supply or oscilloscope, But it will supplement them and allow greater access to Students, Hobbyist and Makers.
    ii. How thoroughly documented were the design process & design decisions?
    The Design Considerations were based on many factors But it boils down to the 3 Basic Designs with improvement iterations.
    Prototype 1 A was designed to be the cheapest unit available.  Focus is to provide users with a Usb Chargeable unit  with 5 and 3.3v outputs as well as an adjustable rail (0.6V - 12V).  Prototype 1A accomplished this with the brute force method and comprised of 133 Components.  The Fabrication came back and was successfully tested.  Ideas of improvement from the Hackaday community sparked a design iteration that would indicate the Voltage even when the device was powered off.
      (Status: Complete and tested)
    Prototype 1B took those considerations and moved the adjustment knob to the center and arranged the LEDs around the voltage control knob.  This allows the user to see the set voltage even before it is turned on.  This offers a problem that not all Potentiometers are accurate and may not line up with the LEDs. To solve this a potentiometer bridges the voltage knob to set its range. and the Lower feedback resistor will be used to set the 0.6V.  In addition, most of the resistors were switched to resistor arrays which offer a tighter layout and easier reflow.  The Boards height as also reduced from 50mm to 38mm, offering a more compact form Factor.
    Prototype 1C took it one step further and integrated a constant current knob.  This works by measuring the load current at the low end and toggling the feedback pin on and off if it exceeds the threshold. Set by the current knob.  The LEDs surrounding the current knob work off sensing the current and using comparators to show the current in increments of 10mA.
    (Status: Currently being Fabricated).
    Prototype 2A was designed to integrate a negative rail for Op-amp usage.  Since this is for a more advance engineer with more demanding and accurate requirements we decided to implement a OLED display to display the voltage.  At the moment we have only done a layout and have not tested the negative rail.  This circuit is to be entirely analog with the display only providing voltage and current feedback.
    (Status: Layout Designed)
    Prototype 3A was designed to be the most advanced and accurate.  It uses a single IC to boost and invert to +-13V.  This is then past through specialized LDO’s that can be adjusted down to 0V.  This method is costly but provides the best performance of all the prototypes.  Like all models the power is accomplished with complete analog and the Samd21 only does sensing and displays the data on the 0.96in Color TFT.  The reason keeping it analog is stability.  We do not want a code error compromising the output.
    Prototype 3B Was designed to make the correction in 3A.  In addition to the +-Rails  are analog and digital inputs that can be utilized by the user.  2 Analog inputs and 4 Digital inputs.  Analog output DAC can also be used to provide small signals for testing.
    Prototype 3C is the moonshot.  The Screen is upgraded to a 1.3” IPS to provide a larger viewing area.  Because of the larger display a SAMD51 is used to keep a stable refresh rate.  This additional area can be utilized for a Crude Oscilloscope and or Logic analyzer
    iii. How ready is this design be taken to market?
    Prototype 1A, 1B and 3A Have been Designed and are currently being tested.  At the moment Additional safety features are being tested including short Circuit, Overload, etc.  These will be read for market within the next month or so.  These will require sourcing and testing to get the cost down as low as possible.
    One of the biggest challenges with this will be sourcing parts and manufactures to keep the cost low.   Currently the entry model uses 5x LM339 Comparators.  Even in quantities of 5 is less than the cheapest MCU.  But there is a point where there are enough led and comparators that a simple MCU and OLED Makes Sense.  Prototype 2A will address this. Within a 2 month Development Prototype 1C, 2A and 3B will be Ready for market.
    Prototype 3C will require additional Assistance as it will need special libraries for the 1.3” display to provide fast enough refresh rate for real time O-scope.  This would require some Assembly level coding.  But once the code is available to everyone improvements in performance can be made by the User base and implemented in future releases.
    Working with Suppliers, PCB Fab and assembly labs will be a major focus of bringing OPEN Power to the Masses.
    iv. How complete is the project?
    The first few prototype are complete and work as intended.  The rest of the iterations will require fabrication and testing before release to the market.  With each Iteration design flaws and the User interface is refined for a more user friendly experience.
View all instructions
Jan wrote 04/18/2019 at 20:21 point
Nice idea. The LED thing is a bit over the top though and occupies much board space! 4x LM339?!?!?!
I wonder how you want to route that thing, there is next to no space for traces in the current design. Using 4 layer boards might work though...
John Loeffler wrote 04/19/2019 at 01:16 point
It is routed on a 2layer.  I have gotten pretty good at routing manually over the years.  Check out my prototype 3 it uses an 0.96 color Toft display and has loads more features.
Lukas wrote 04/15/2019 at 08:48 point
Great idea, i need this for my breadboard.
testsubj wrote 04/11/2019 at 18:56 point
There's already some similar boards on Aliexpress that do this. I didn't look for an adjustable version, but the ones that only output 3.3/5 cost less than $1 shipped.
John Loeffler wrote 04/11/2019 at 18:59 point
I love those.  This is usb powered with Lipo backup, as well as continuously adjustable and 5v and 3.3v rails
Dan Maloney wrote 04/11/2019 at 15:12 point
Agreed - great idea. You should really enter this is the Hackaday Prize - this would make a great product!
John Loeffler wrote 04/11/2019 at 15:15 point
Thanks I will,  Check out my Prototype 3.  It has more bells and whistles.  This version is a simple non Micro controller version. Right now the cost of components is less than $4 in low quantity.
Lee Wilkins wrote 04/10/2019 at 20:37 point
Great idea!
