Variable Voltage / Load Sharing / Uninterruptible Power Tests
A project log for OPEN Power
I didn't have enough to buy a Lab Bench PSU... So I made one.
john-loefflerJohn Loeffler 08/19/2019 at 19:500 Comments
Testing the SEPIC Converter and LED Feedback of the adjustable rails.  The pot is calibrated by an additional bot on the bottom for accurate voltage readings.  When the LED begins to flicker it is almost at the desired voltage.  When it just becomes solid it is at the desired voltage.
When USB Power is applied the battery is disconnected and will be charged if needed.  When Usb is disconnected the battery will be enabled allowing continuous operation.
