Portable Retro Game Console with 7.9-inch display
A Raspberry Pi-based console - Made for retro game emulation.
cc
This is my Raspberry Pi 3-based portable console, I designed and built from scratch.
The system is built around emulation and plays classic consoles like the Sega Megadrive, Super Nintendo, Game Boy Advance, PlayStation and many more.
 Specifications:
DimensionsWidth: 277 mm (10.9 in)
Height: 134 mm (5.3 in)
Depth: 21 mm - 25 mm (0.83 in - 0.98 in)
SBCRaspberry Pi 3 A+
Display7.9-inch in 4:3 aspect ratio, 60 Hz 2048 × 1536 IPS LCD
AudioTwo 3 W speakers Ø28.5 mm (1.1 in), 3.5 mm headphone jack
BatteryLi-Po battery/8000 mAh (3 to 6 hours of game playing)
Power LEDWith low, charging and charged battery indicator
Storage16 GB MicroSD card
Size comparison:
  • 1 × Raspberry Pi 3 Model A+
  • 1 × LG Display 7.9" 4:3 aspect ratio, 2048 × 1536 IPS LCD.
  • 1 × Red & Green LED (3mm)
  • 1 × NeoPixel LED
  • 1 × Heat sink For the Raspberry Pi.
View all 20 components
View project log
William Easdown wrote 20 hours ago point
This looks like a really slick project, well done! Could you clarify please whether the current case is 3D printed or injection moulded? It looks too smooth to be 3D printed to me. 😄 If it is 3D printed, I love to know which printer you used.
c wrote 11 hours ago point
Thanks! It's actually 3D-printed with a Wanhao Duplicator i3 Plus. And with a lot of sanding ;)
But I'm currently working on a silicone mould for it.
JavaScriptMike wrote 2 days ago point
I was looking at the design,  I would be interested in building this project myself.  Is there any way I can get the 3d print files for the case body?   Or is it 3d printed or purchased from somewhere else or what?
c wrote 2 days ago point
I'm still working on some adjustments on the 3D-files. I want to complete all that before I release them ;)
Daren Schwenke wrote 5 days ago point
This looks like a very polished 'instant' project.  Documenting your journey to this point would help.  Got any build logs, stl files, or pictures of the inside?
Thanks. Unfortunately, the sd-card in my old camera got corrupted. So I lost all the pictures I had.
But I'm working on it :)
fabian wrote 6 days ago point
nice but .....
1. i need usb c
2. i need small hole for rope
3. how writing wifi password? beybe add normal usb A?
4. how long this device working? if i can play 5h i dont but this device. I need 12h minimum
5. meybe put fpga for reducing power
6. where are rotor potenciometer? tell me how play in tempest with keys, impossible
James Hall wrote 6 days ago point
You don't need much do you?
c wrote 6 days ago point
1.
Maybe later.
2.
Sometime, maybe.
3.
You don't need to connect a keyboard to write the password to the Wi-Fi. There's an on-screen keyboard that pops up when you want to write, so you just use the buttons on the console ;)
4.
12 hours will be pretty hard to achieve with a display this big.
It would have to be around 20 000 mAh, and a battery of that size won't fit at the moment.
ebaystudio wrote 05/17/2019 at 17:42 point
I see it for sale on etsy but will there be a DIY available. Can you release the STl's? Thanks
antennas wrote 05/17/2019 at 16:53 point
Very nice! Please share how you drive the display and where you bought it. A lot of folks would like to build this as well.
Thanks! I couldn't find the same model right now. But it was similar to this one:  https://ebay.us/TgBYhk
Mike wrote 05/17/2019 at 15:24 point
Would love to get the CAD files for this and a parts list.  I am very interested in building.
A L wrote 05/16/2019 at 22:34 point
How are you driving an eDP panel from HDMI?
c wrote 05/19/2019 at 13:38 point
With an adapter ;)
Chris Barrett wrote 05/16/2019 at 20:30 point
What about Left Shoulder / Left Trigger ?=  LS/LT RS/RT
Or Left Shoulder 1 / Left Shoulder 2? = LS1/LS2 RS1/RS2
c wrote 05/19/2019 at 13:37 point
Yeah, hopefully I can use one of them ;)
Thanks!
l3oomll7 wrote 05/08/2019 at 04:08 point
nice project
c wrote 05/09/2019 at 16:00 point
Thanks!
Paul Henderson wrote 04/24/2019 at 21:28 point
Hey @c , can we get the 3D files for the case? I have most of the parts on hand and would love to give this a shot. Thanks!
alireza safdari wrote 04/16/2019 at 00:08 point
If you want to commercialize this in future consider not calling the buttons L1 & L2 and R1 & R2. It may get you in trouble
c wrote 04/16/2019 at 00:40 point
Really? Are those names trademarked?
alireza safdari wrote 04/16/2019 at 01:16 point
@c I was under the wrong impression that Sony only calls them L1, L2, R1, R2. But apparently that is not the case (I am still not 100% sure). I did a patent search in sony products and Dual shock controller does not disclose the buttons' name: https://patents.google.com/patent/US6394906
I found an earlier patent that does disclose the name for the buttons: https://patents.google.com/patent/JP4036246B2/en?oq=6%2c394%2c906
But if all other companies are using L1, L2, R1, R2; I guess you should be fine. However considering that your device look very similar to PSP (the look), I would call these something else to be safer (take note I said safer and not safe) if there is a lawsuit in future
c wrote 04/16/2019 at 10:17 point
@alireza safdari Oh, ok. Maybe I should change the names, just to be on the safe side.
Do you have any suggestions?
alireza safdari wrote 04/16/2019 at 13:50 point
@c  If I am not mistaken "Right Trigger" and "Left Trigger" is another name widely used (I saw it last night in the result of my google image search). But I am the worst person to ask because I was never a gaming freak.
c wrote 04/16/2019 at 22:41 point
@alireza safdari Ok, thanks! I will research this further :)
alireza safdari wrote 04/17/2019 at 01:47 point
@c All the best. :)
