Portable Retro Game Console with 7.9-inch display
A Raspberry Pi-based console - Made for retro game emulation.
cc
This is my Raspberry Pi 3-based portable console, I designed and built from scratch.
The system is built around emulation and plays classic consoles like the Sega Megadrive, Super Nintendo, Game Boy Advance, PlayStation and many more.
 Specifications:
DimensionsWidth: 277 mm (10.9 in)
Height: 134 mm (5.3 in)
Depth: 21 mm - 25 mm (0.83 in - 0.98 in)
SBCRaspberry Pi 3 A+
Display7.9-inch in 4:3 aspect ratio, 60 Hz 2048 × 1536 IPS LCD
AudioTwo 3 W speakers Ø28.5 mm (1.1 in), 3.5 mm headphone jack
BatteryLi-Po battery/8000 mAh (3 to 6 hours of game playing)
Power LEDWith low, charging and charged battery indicator
Storage16 GB MicroSD card
Size comparison:
  • 1 × Raspberry Pi 3 Model A+
  • 1 × LG Display 7.9" 4:3 aspect ratio, 2048 × 1536 IPS LCD.
  • 1 × Red & Green LED (3mm)
  • 1 × NeoPixel LED
  • 1 × Heat sink For the Raspberry Pi.
View all 20 components
View project log
fabian wrote 17 hours ago point
nice but .....
1. i need usb c
2. i need small hole for rope
3. how writing wifi password? beybe add normal usb A?
4. how long this device working? if i can play 5h i dont but this device. I need 12h minimum
5. meybe put fpga for reducing power
6. where are rotor potenciometer? tell me how play in tempest with keys, impossible
James Hall wrote 13 hours ago point
You don't need much do you?
c wrote 7 hours ago point
1.
Maybe later.
2.
Sometime, maybe.
3.
You don't need to connect a keyboard to write the password to the Wi-Fi. There's an on-screen keyboard that pops up when you want to write, so you just use the buttons on the console ;)
4.
12 hours will be pretty hard to achieve with a display this big.
It would have to be around 20 000 mAh, and a battery of that size won't fit at the moment.
ebaystudio wrote 5 days ago point
I see it for sale on etsy but will there be a DIY available. Can you release the STl's? Thanks
antennas wrote 5 days ago point
Very nice! Please share how you drive the display and where you bought it. A lot of folks would like to build this as well.
Mike wrote 5 days ago point
Would love to get the CAD files for this and a parts list.  I am very interested in building.
A L wrote 5 days ago point
How are you driving an eDP panel from HDMI?
c wrote 3 days ago point
With an adapter ;)
Chris Barrett wrote 5 days ago point
What about Left Shoulder / Left Trigger ?=  LS/LT RS/RT
Or Left Shoulder 1 / Left Shoulder 2? = LS1/LS2 RS1/RS2
Yeah, hopefully I can use one of them ;)
Thanks!
l3oomll7 wrote 05/08/2019 at 04:08 point
nice project
c wrote 05/09/2019 at 16:00 point
Thanks!
Paul Henderson wrote 04/24/2019 at 21:28 point
Hey @c , can we get the 3D files for the case? I have most of the parts on hand and would love to give this a shot. Thanks!
alireza safdari wrote 04/16/2019 at 00:08 point
If you want to commercialize this in future consider not calling the buttons L1 & L2 and R1 & R2. It may get you in trouble
c wrote 04/16/2019 at 00:40 point
Really? Are those names trademarked?
alireza safdari wrote 04/16/2019 at 01:16 point
@c I was under the wrong impression that Sony only calls them L1, L2, R1, R2. But apparently that is not the case (I am still not 100% sure). I did a patent search in sony products and Dual shock controller does not disclose the buttons' name: https://patents.google.com/patent/US6394906
I found an earlier patent that does disclose the name for the buttons: https://patents.google.com/patent/JP4036246B2/en?oq=6%2c394%2c906
But if all other companies are using L1, L2, R1, R2; I guess you should be fine. However considering that your device look very similar to PSP (the look), I would call these something else to be safer (take note I said safer and not safe) if there is a lawsuit in future
c wrote 04/16/2019 at 10:17 point
@alireza safdari Oh, ok. Maybe I should change the names, just to be on the safe side.
Do you have any suggestions?
alireza safdari wrote 04/16/2019 at 13:50 point
@c  If I am not mistaken "Right Trigger" and "Left Trigger" is another name widely used (I saw it last night in the result of my google image search). But I am the worst person to ask because I was never a gaming freak.
c wrote 04/16/2019 at 22:41 point
@alireza safdari Ok, thanks! I will research this further :)
alireza safdari wrote 04/17/2019 at 01:47 point
@c All the best. :)
