Axiom: 100+kW Motor Controller
High Power, High Performance 400V 300A 100+kW Motor Controller fully compatible with VESC®
Public Chat
For the first time in history, Axiom provides clear, wide open access to the precise control of large 3 phase motors. And it couldn't be more timely, billions are spent accelerating the incoming era of electric vehicles, with massive EV fleet growth, and so many small and big companies competing to have a dominating role in the future of transportation.
It is put together by Marcos -MIT TR35-, endless-sphere forum legend HighHopes, 1/4 mile EV WORLD RECORD HOLDER Arlo1, highest-engineering-grades Maxi, and using, improving and accelerating the cult-following work of Benjamin Vedder with a stream of new firmware code to make humanity better at spinning motors!
It’s not only a feature rich high performance controller, it also comes in a power dense package. The best part of course is the hardware and firmware are open source! Making the schematic, BOM, and code available for everyone to experiment and improve, its the ideal platform for vehicles, research and industries
This project was released in endless-sphere forum, here's the thread where the discussion takes place: https://endless-sphere.com/forums/viewtopic.php?f=30&t=89056&start=250#p1458465
Check out why Axiom is an awesome candidate for the Hackaday Prize!:
https://hackaday.io/project/164932-axiom-100kw-motor-controller/log/166680-dear-judges
What is it?
It is a 3 phase motor controller. It takes a DC voltage and generates 3 sinewaves for driving a motor, conceptually similar to those small ESC for drones and bikes. The difference is that this particular setup can safely work with a 400V battery, flowing 300Amps all year long.
Our work has been focused in the control board, which is capable of driving way more than 400V and way more than 300A, those are defined by the powerstage ratings.
We chose EconoDual IGBT modules because its a popular package, they come in many voltage and current levels (from 600V to 1700V, and from 100A to 1000A), from many brands, in both IGBT and SiC technology and with available off the shelf gate drivers matched for them.
Why?
Because we want to be part of the boldest, most spectacular builds, there is no other open platform capable of driving a 100kW-class motor. All you can get are proprietary controllers with high markups and no way to tweak them to your needs, and most importantly, you don't get to see the inner workings to evaluate if the quality is up to your standards, both in software and hardware.
The new wave of EV companies have been tied to proprietary motor drives, we provide our customers with a chance to deeply integrate the motor drive into their systems, offering a unique chance of verticalization within their product. This saves costs and improves the quality and integration of their vehicles.
Opening up Axiom also showcases the quality of our work and makes our team a desirable contractor, there are not many people in the world with the set of skills and knowledge to produce a high performance drive unit.
Axiom is also made possible thanks to the VESC® base platform growing steadily to the point we can take it for the first time to the next level, from a hobby tool to a full EV-capable piece of technology.
Who is using an Axiom?
Since we went public this year several individuals and engineering teams around the world signed up for ordering an Axiom. We are currently on a beta testing stage, only picking the most equipped engineering teams capable of providing us with valuable feedback to make sure we deliver a solid product. Well over a hundred direct requests were handled, here are some of the teams with an Axiom controller under test:
We are covering 5 continents!
Roughly half of the applications are for traction vehicles (cars, bikes, racing), others are for aircraft, and some are pure R&D departments.
Contact us if you want to apply to be a beta tester!
What can you do with an Axiom?
Pretty much anything involving a powerful 3 phase motor.
  • Electric Vehicle conversions
  • EV racing
  • Mining
  • OEM EV like bikes and ATV
  • Subsea ROVs
  • Aircraft systems (*)
  • Glider launchers (*)
  • Wind generators
  • R&D
Did you imagine this could be used to launch a glider? We neither! That list mostly comes from meetings with our customers.
Why do they choose us?
Because the performance and the user experience of a VESC® system are simply top notch. The user needs an interface to configure the motor parameters, and it will be the main tool for debugging problems and getting to know the machine. Hats off to Benjamin's VESC Tool:
With software and firmware in place, a high power application will need some very particular hardware:
Here is our take at this:
  • Mechanically matched to EconoDual/17mm IGBT modules. More compact, fewer assembly steps, less wiring and crimping, no adapter parts.
  • Isolated HVDC and phase voltage monitoring integrated on board, direct connection to the IGBTs for cleaner signals and faster assembly.
  • DC...
Datasheet-Axiom-control-board.pdf
Axiom Rev1 control board datasheet
Adobe Portable Document Format - 2.93 MB - 09/24/2019 at 19:46
Preview
Download
Axiom_Rev1_schematic.pdf
Axiom Rev1 schematic top level
Adobe Portable Document Format - 3.47 MB - 09/10/2019 at 10:20
Preview
Download
Axiom-Rev1_BOM.xlsx
Axiom Rev1 board Bill Of Materials
sheet - 16.00 kB - 09/10/2019 at 10:18
Download
Axiom Rev0 schematic Block Diagram
Portable Network Graphics (PNG) - 3.76 MB - 04/29/2019 at 11:41
Preview
Download
pinout_drawing_rev0.pdf
Axiom Rev0 and Rev1 Control Board Pinout
Adobe Portable Document Format - 6.05 MB - 04/22/2019 at 23:40
Preview
Download
  • 3 × FF600R07ME4B11BOSA1 650V 600A IGBT module
  • 1 × PD-Axiom-Rev0 Powerdesigns Motor Control Board, Compatible with VESC platform
  • 3 × 2SP0115T2A0-06 Gate driver for FF600R07ME4B11BOSA1
  • 3 × ISB-425-A Busbar Hall Current Sensor
  • 1 × PD-C600VDC-650UF10A Powerdesigns DC Link Capacitor, 600Vdc 650uF +-10%
  • Meet our customers!
    Marcos09/24/2019 at 15:51 2 comments
    If there is something we can't complain about is a lack of demand and kind words!
    Since we presented Axiom we got a constant flux of requests from individuals, about 200 direct requests were handled (9 in the last 7 days for example) and our newsletter has 300+ subscribers which is impressive because we are talking about a high end piece of hardware.
    Let's see more details:
    • Most requests came from individuals looking for converting their own vehicles to electric, from old hondas like Arlin's to Beetles, BMW's and even an Audi R8 supercar.
    • Some were companies in very niche markets
      • Big underwater robots and vessels
      • Jet boats
      • Vehicles for mining
      • EV conversion shops
      • Aircraft startups
      • Sportsbikes startups
      • Wind generation
      • Glider launchers
    • There are Axiom controllers already in the (slow) order queue of a couple of billion $ marketcap companies diving into the future of electrification.
    • Research teams are also keen to have an Axiom as a tool
      • 2 formula SAE teams got their Axioms
      • R&D departments at universities
      • Electric motor manufacturer
    • And there is the community, which makes it possible that a fleet of thousands of small VESC controllers in the field are piling up miles of continuous firmware testing. Those may lack a fancy and expensive LTE network, but the VESC platform has a ton of users happily reporting issues in the forums.
    The Axiom development and documentation in the hackaday platform also made possible to get our team in sight of other big companies that need some very special motor controllers with specs and qualifications that Axiom is not meant to meet. If we actually land one of those contracts I would bet that the experience will influence Axiom development to make it even better.
    Enough words, let's see a couple of beta testers in action:
    VESC Tool has built-in functions to program and plot load tests like this one performed in California
    Abricosvw testing and learning (we all learned from his experience).
    300V 300A flowing somewhere in Europe
    I lost some cool videos from pymco.fr with my phone, but PYMCO was the early partner of Axiom and I personally handed them control boards in both vacations and honeymoon! They were the first ones to drive a REMY motor with a VESC.
    Axioms has been sent for prototyping and R&D to Turbotech in France
    700Amps somewhere in India
    Somewhere in Africa there are mining machines needing an Axiom on each wheel! This customer is waiting for the control boards to ship and they are ready to start testing.
    This CRX is Arlin's, but very similar to another car that is powered by an Axiom. (note the motor reaches max speed for that battery in 60 milliseconds)
    And this is in our bench showing a somewhat representative testing like a customer would do, they only should add a mechanical load. This was filmed last year when automated tests were not yet coded into VESC Tool.
    A critical customer, or should I say partner, is Benjamin, the VESC architect itself who is planning to jump on board of an Axiom next week to turn the power to eleven.
    So far the beta test stage...
  • FPGA: What's next?
    Marcos09/22/2019 at 15:06 2 comments
    Our last episode covering the FPGA capabilities deserved a quick followup to shed some light into what's coming next in the hopefully near future:
    Icestudio GUI getting huge improvements
    Hardcore developers will handle any problem with any fpga using any language to get things done. For the rest of us, its neat when the user interface is friendlier than a bunch of HDL files.
    Several updates happened to the icestudio.io project, with massive speedups showing up in the nighties. This speedup is allowing to work with really large FPGA projects.
    Lets see a couple of examples from the developers mailing list. The list is in Spanish so its good to unearth that huge effort and show a bit what's going on there.
    Z80 processor + peripherals
    This is not just a drawing, this is the actual view in the ice40 Icestudio editor. You can actually drop a Z80 CPU, UART, RAM, Bootloader and GPIO blocks into icestudio. Verify, synthesise, and upload to the target is a breeze.
    Yes, this is really happening, in a fully open source FPGA toolchain! It was about time, after all we were promised 2019 was the year of the FPGAs
    RISC-V + peripherals
    Z80 not cool enough for you?
    There is a RISC-V core available and passing tests on the ice40 devices, together with a UART, RAM and external flash management ready for you to discover and try out. Kudos to Obijuan for sharing this demo!
    The coolest bit of this is that you can use gcc to compile C code that runs in this softcore, and the code example is awesome, directly accessing your custom "peripheral" from the address map:
    You can see it doesn't need any fancy include, and when you consider it was you who built the whole cpu logic, its just mindblowing.
    An actual motor control application
    Alright alright, that toolchain is very cool, but how does it benefit my motor control application?
    The main point of Axiom having an FPGA is to digitize earlier the analog signals.
    These digitizers are footprint compatible with the AMC1302 iso-amps currently installed which are actually delta sigma converters but they convert the signal back to analog domain. By swapping them you can digitize right at the High Voltage domain, and it stays digital until it reaches the microcontroller for field oriented control calculations.
    What's the benefit?
    First you can ditch all these analog signal processing components, they are a big chunk of the BOM and pcb area!
    All these components can be removed if Axiom goes digital
    Not only they add cost to the BOM, but most importantly they add ageing, temperature and tolerance drifts; supply rail variations and EMI will creep up into the measurements, and in these critical applications, every parameter drift has to be studied to perform the design assurance our big customers are already requesting.
    For example if the signal chain has x2 opamps, x7 1% resistors and x4 10% capacitors, you can calculate the worst case scenario in which the signal chain will have 10% of error. That's likely unacceptable, so you run a Monte Carlo analysis that tells you that 99.8% of the boards will meet <5% tolerance, but now you need to test every board under various conditions looking for the 0.2% that needs to be scrapped or somehow tuned.
    Enter the digital signal path
    Everything we did in the analog domain we can do it in its digital counterpart. Drop a delta sigma demodulator block, a sinc filter, a decimation filter and you are ready to go. This takes only a few hundred logic blocks.
    Figure 3This signal chain and its benefits are well documented in this article by Analog Devices
    For the hardware overcurrent/overvoltage comparators there are methods that will detect the incoming fault within 4 us with a few logic gates. That's...
  • Making hardware. The hard way.
    Marcos09/14/2019 at 20:21 3 comments
    Even if the VESC platform was born in the green and thriving lands of Sweden, the Axiom project found its roots in much less fertile soil.
    This particular log is likely going to go over the heads of the folks living in developed countries -even my newfound Canadian mates-, but I think it can resonate a lot on the rest of us.
    There are many great stories about large companies being born in a garage near Silicon Valley, but for many of us a garage in a developed country is a dream, you can't help but feeling hopelessly excluded from the aspiration of achieving such great feats.
    Like most people in this community, I started working with my mate Maxi in my dad's garage. But our garages come with some extra handicaps, they are located in a  ̶d̶e̶v̶e̶l̶o̶p̶i̶n̶g̶  collapsing country that has been edging populism for years. Argentina has been home of brutal customs paperwork and requirements to deter people from ordering stuff from other countries (think digikey, a pcb, or a fancy oscilloscope), plus 50% of import taxes and the recent come back of the immediate "pesification" of the income we get from international jobs (it means that if you charge $100 for a prototype, it gets converted to a devaluating AR$, you never get to hold USD, even if you need to order stuff in USD to do the job). The concept is to take money from the productive sector to fund government affairs, so being productive here takes way more effort and willingness.
    After we got our engineering degrees we started the search for contracts and good ideas. We landed a nation-wide award for a top 5 most innovative product and all that $ was invested in setting up our current Palta Tech lab and a corporation figure that can import stuff. You may imagine a sci-fi lab... and you would be right!
    Meet our Batcave in Argentina
    That's the current google street view, It took us an entire summer of sanding the old paint, preparing and painting the inside, the award couldn't afford the paintjob (much less pavement!). The lab outside is nicer looking now, but google won't notice for years because they don't come here often.
    Having a workplace we focused on the actual work, contributing to VESC, earning some traction in the forums, and meeting amazing people like our canadian mates Arlin and Sonny, and the oh so fulfilling development of Axiom, which made our team an international, far reaching endeavor. We still ship boards from Argentina, but with a new company in canadian jurisdiction we are trying to leave behind the struggles.
    It takes years of (extra) effort to get you this far when you live in a poor country, and this log has 2 purposes:
    • To serve as inspiration to all those hackers and makers that keep creating despite adversity.
    • To raise some awareness about how awesome and valuable it is to have a makerspace near you and same-day tax-free no-BS shipping! Makers around the world don't take these resources for granted, many have to build labs from the ground up, design their own CNCs and deal with customs and government BS to stay competitive.
    I don't know if there are other hackaday prize finalists emerging from a non-developed country this year, certainly not many. Hopefully this will help more outsiders getting into the business!
    Marcos
  • A note on supply chain shortages
    Marcos09/10/2019 at 02:35 0 comments
    Many times we designers face an unassuming challenge. Pick the latest and greatest part... or go the old way and pick a less fancy part that gets the job done.
    In this design the design for manufacture is important, and that includes the analysis of potential supply chain shortcomings.
    In particular, the neverending issue of parts getting out of stock right before you hit the big red "MFG" button.
    This could be less of a concern if the board had 10 or 15 types of parts, but with 100+ lines in the BOM, the odds are against you.
    We can classify the risk of a non-stock line according to the damage it creates to the production schedule. For example if a resistor goes out of stock you can easily change the part#... but if suddenly your microcontroller goes unobtanium you are screwed. What's the cost and time required for software migration, testing, and pcb update and re-tooling? Hint: its very non-zero.
    So for Axiom there are only a few dangerous components in this regard, and we can show the countermeasures we have taken:
    MCU: A shortage of STM32F405 would be a disaster for a product like this, as the firmware despite making extensive use of ChibiOS its still heavily interwinded with low level peripheral access for max performance, so no easy migration.
    Luckily we have a viable replacement that is the STM32F407, which is pretty much the same die with an ethernet peripheral. It can be more expensive but you don't care when you're against the ropes handling a shortage. Also, these ST oldies are ubiquitous and heavily stocked, it would be super odd to see a shortage.
    FPGA: In general I find most HDL design software to be full of crap, so going for an open source toolchain gives some peace of mind here, as you could be locked away due to licensing for example. Then there is regular part# issue, which is actually what triggered this log.
    Right now the super cool and amazing FPGA Axiom uses is non stocked in the major suppliers, so one would have to start poking the manufacturers or the shady suppliers that apparently have the part but you never heard of them. But here is where the strategy shines, we have already identified this as a possible issue and early in the game we developed the verilog code for a different family of fpga that happens to be pin compatible, and I assembled, tested and validated the board with the alternative part, so we were always ready for a shortage.
    Connectors: Here's the weak point in our supply chain. Even if JST connectors, and Amphenol RJ45 - 4 port assemblies are common, there are no alternatives in the current design, so in case of a shortage its likely that we will need to update the pcb design and have a talk with the assembler about the change. This little deviation can easily translate to a $200 fee. At least there is no software development involved and likely no need to update the user manual.
    IGBT's: This is another example of a part that can become difficult to source. The IGBT listed in the BOM is currently out of stock, but this is where the choice of using EconoDual becomes evident: we can easily use another part with the same package! So for now we upped the part voltage from 650V to 1200V, but there are many options, even a 1200V 1000A part is available (more about that in a future episode)
    Power supply: You'll see that the LDO has non populated feedback resistors, thats because it allows to use the adjustable version in case the fixed 3.3V version goes dark. It also allows to run the MCU domain at a bit higher voltage, like 3.45V to have a bit better signal/noise ratio on the analog frontend (this has been validated on consumer grade boards but not for the high power builds)....
  • Video Introduction - Axiom Motor Control
    Sonny Lloyd08/24/2019 at 13:46 0 comments
    As our project followers already know, Arlin Sansome has started re-building his world record breaking Honda CRX for higher power, higher performance with Axiom Motor Control.  In this video Arlin shares the motivation for this project, describes the Axiom Hackaday project and shows a sneak peak at our first full up motor controller prototype (more on that later).  For now, please enjoy the video and be sure to ask your questions and leave your comments here :)
  • Schematic released!
    Marcos08/22/2019 at 03:18 0 comments
    It took us long enough, but we have finally converged to a releasable schematic!
    Take a look for yourself:
    http://www.powerdesigns.ca/files/Axiom_Rev1_schematic.pdf
    I really don't remember seeing a schematic this complete, clear, complex, and public! Most of the team worked at aerospace and military organizations, so we know a thing or two about these documents and that experience was put into practice here. It is released under a Creative Commons BY-SA license.
    Take for example a simple component like any of these capacitors.
    Is the capacitance important? Of course! Is the rated voltage important? You bet!
    A wrong capacitance value can be harmless, or detune a timing or filtering circuit. But using a 6.3Vdc capacitor on a 15Vdc rail will have dire consequences, hence the need to be verbose when drawing the schematic and be clear about the used ratings. You don't see this often in public schematics.
    Resistors power rating present us a similar case. Take for example the CANbus termination resistor:
    Can it withstand a continuous bus failure? If we are clear about the power ratings we can see that the termination resistor pair can take 500mW.
    5V on a 120 Ohm resistor gives 208mW, so it should be alright. The DC Link discharge circuit needs to pass this continuous bleed check, with some extra safety consideration regarding discharge time.
    Then you have the more common practice of drawing the signal flow from left to right, for example in the signal conditioning circuit (there is one of these blocks for each phase):
    Many people asked about the FPGA implementation, and its a straightforward one.
    It is configured over SPI, pwm signals are level shifted from 3.3V to 5V for better integrity under high EMI. The SPI bus can be used for high speed general purpose communication between MCU and FPGA. The ice40up5k eval board had some errors that were fixed in Axiom schematic regarding PLL supply filtering and power supply sequencing.
    So there you have, an earth-shattering, high quality 34 page document meant to bring electric vehicles and high power motor control closer to everyone!
    PS: Schematic was first released days ago to our newsletter subscribers. Subscribe now to hear first about Axiom news!
    http://www.powerdesigns.ca/newsletter/
  • Design Decisions Philosophy
    Sonny Lloyd08/17/2019 at 03:41 2 comments
    You can have it good, fast, or cheap. Pick any two. Good and fast, it will be reliable but expensive to design. Fast and cheap, probably going to end up with something that causes fires rather than drives an EV. Cheap and Good is possible but it’s going to take some time to deliver. Obviously there are many design decisions made along the way of producing a final schematic and bill of materials for a high performance full up motor controller. But how are those decisions made? That is the focus of this log post.
    And it turns out.. it's not that hard. During the initial project meeting EV Power Designs asks the client what are their top three priorities. Cost, weight, volume, performance, reliability, protection from obsolescence, manufacturability, time to market and so on. OK, I lied. It's hard; because after all don’t we want it all? Pick only three? This simple question tends to bring out a lot of discussion about the client’s expectations, desires, goals and general philosophy. The client gets to hear about how each design objective will influence the actual product so there is an appreciation both ways. Client and consultant get an opportunity to better understand the project but more importantly, each other. From this conversation, the three .. yes only three.. top priorities will eventually be ascertained.
    Here is an example of how narrowing down the product development philosophy to three key drivers can help with decision making.  Let's say the three most important goals are Weight / Volume / Cost (typical for new power electronics design where time to market is not a key factor). How does this impact the decision for torque control, arguably the most important function of a motor drive? Depending on the power level there are a lot of different design paths that will lead to lower weight, volume and cost but at all power levels it's possible to reduce the phase current sensor count from three to two. The motor load is still 3-phase, but the current in only two of three phases is measured for control purposes.  The current sensor required for high performance motor drive is relatively expensive because it must be high bandwidth and low error so removing one out of the system saves a lot of cost. And the thing is rather large and heavy because of the internal ferrite core, so weight and volume come down as well. It's a win… win and win. but. As my old professor used to say, you never get a free lunch in engineering. There is a small price to pay to have higher performing op-amps that are now required for adequate design purposes, and with only two sensors the system will never be aware of circulating currents and thus never have the ability to eek out some more performance by nulling out the circulating current. Or in other words… with only two sensors, the system just became lower performance.  Thankfully, in this example, performance wasn’t one of the top three design goals.
    We applied this same philosophy to the Axiom control board design process. What three top priority goals should we have? Performance, reliability and versatility.
  • Dear Judges
    Marcos08/06/2019 at 20:21 0 comments
    Dear Judges
    It’s tough to get through hundreds of projects, here is some help!
    i. Is this a unique solution to a particular challenge facing the world today?
    There are lots of motor controllers out there, good, bad and ugly.
    There are few motor controllers capable of moving a car.
    There are no open source motor controllers capable of moving a car and pushing the boundaries and reach of electric vehicle technology like Axiom does.
    And the world certainly needs to get good at this, motors are driving our civilization and comprise most of the energy usage, we need to accelerate our motor control tech. The best way to drive the technology forward is to open it up to the world, open source, and let all the clever and hyper interested people join together in one reliable, high power, high performance, flexible platform we’ve called Axiom.
    ii. How thoroughly documented were the design process & design decisions?
    I’m sure you’ve already read the project logs and really appreciate the magnitude of our work. The core work of the Axiom project is the schematic, bill of materials and main processor firmware; all open source. Although it only took a few weeks to generate the schematic and bill of materials, they are based on nearly two decades of intense professional design for high performance electric vehicles as well as commercial and military aircraft. In fact, the team members came together on a side project (managed by Arlin Sansome) to help with some of the motor control technology elements to push the boundary beyond reasonable limits, directly into world record breaking limits. Needless to say there is a wealth of experience on the team which allows for generating working schematics in a short period of time.  The design itself is heavily documented. Simulation using Matlab/Simulink and PSpice helps to define circuit functional basics to system integration. MathCAD/Smath was used for much of the advanced analysis such as electrical stress, component sensitivity and tolerance analysis.
    iii. How ready is this design be taken to market?
    Several individuals, companies and universities are already stretching the muscles of their Axiom drives. We have been selling beta boards and complete controllers for a few months now to get early feedback while simultaneously building up some operational hours to prove out the design. We are expecting to take the product to market in 2020 for turn key 100kW motor drive power.
    iv. How complete is the project?
    Axiom is a complex convergence of mechanical engineering, electrical engineering, thermals, firmware, software, safety, racing, distributed work, user interface, artwork and the will to meet the most challenging requirements.
    The Axiom control board product is already complete, working to control a limited number of high powered motor drives all over the world and will be available with all the bells and whistles in a complete high power, high performance, full up motor drive in 2020.
    Finals
    i. Concept- Is the project creative, original, functional, and pushing boundaries? Does the project benefit society in some way?
    Axiom sports a creative assembly to simplify the production, it's been proven by many customers, not to mention the thousands of smaller controllers out there using the same VESC software we use and contribute to, and it is fueling the boldest high power applications not only electric cars but also turbogenerators, bikes, ROVs, big machinery and more.
    If Axiom succeeds in its quest, the whole world will become better at spinning motors -one of the major energy consumers-. Pushing the boundaries is exactly where the Axiom product positions itself. An earlier version of the hardware broke the world record for fastest front wheel drive car on the ¼ mile¹. In fact, Arlin is currently working...
  • New feature: GUI CANbus support
    Marcos07/18/2019 at 22:19 0 comments
    Because we can have nice things
    Consider your regular dayjob (or dayhobby) of using an Axiom-based controller. You are likely dealing with a silly amount of current, or voltage, or both, and you have to *work* with that while being safe. It is also likely that you need to work on more than one motor drive at a time, for example when you have an AWD dual motor honda CRX, or a one-motor-per-wheel setup with torque vectoring, or you are just stress testing 10 drive units in a test facility and you want them in a network.
    In those cases, the good'n old USB interface of the vesc platform just doesn't cut it because a compromised isolation barrier in one controller will expose your computer to unsafe voltages.
    For those cases we equipped every Axiom board with a couple of isolated CANbus interfaces: its the safest way to interface with a motor drive, providing a second isolation barrier with super low capacitive coupling for highest noise immunity.
    And when you need to address several controllers, well, CANbus is the perfect protocol as it allows to send or receive commands from any node in the network. Within milliseconds you can send torque commands to 4 controllers in the bus.
    But there was a missing piece in the VESC platform: you couldn't directly connect to a CANbus with the VESC Tool GUI.
    Until now!
    Native CANbus support for VESC Tool
    See here our Pull Request that adds native support for a can interface. You can discover all VESC's in the network, connect to one and perform firmware updates, realtime data acquisition, high speed sampling, motor detection, parameter config, etc, everything from the GUI.
    This works nicely on linux. For windows support you may have to wait, code it, or hire someone to code it for you ;-)
    It opens the door for proper instrument clusters
    Something we want to address is data display. Whether its a sportsbike, a car, a plane or a jet boat (yes Axiom is already serving all those applications!) the human interface needs to be pretty, with Qt libraries we can do much better than a hacked gauge display
    With VESC Tool codebase being capable of accessing the bus, it is now much easier to install a Beaglebone or a RPi in the vehicle with an industrial monitor and run a nice instrument cluster like this example from the internet that I compiled a couple of years ago on my old laptop.
    Both VESC Tool and this example are based on Qt5 libraries. We hope to see some nice VESC displays in the future thanks to this
    Update: we have a dashboard getting data from the controller:
    In-house CANbus<->USB adapter
    And here is the icing of the cake: every Axiom controller will come with a compatible CANbus<->USB adapter, using the open source candlelight firmware, and with perhaps the nicest build quality out there:
    A few highligths:
    • Aluminum shell. We machine it alongside the IGBT phase bars as they are of similar thickness
    • UAVCAN compliant CANbus connector (SM04B-GHS). Its also the same used by Axiom
    • Nicely embedded dipswitch to enable 5V bus supply, bus termination resistors and bootloader mode. This replaces the sloppy pin header jumpers.
    • All the performance and features of candlelight firmware that now works out of the box with VESC Tool
    I ordered some boards to assemble in-house, if they turn out good we can send a batch for mfg. Being the coolest CAN<->USB converter out there it should sell well, not only to Axiom users.
    Note that the boards are panelized, with tooling strips that provide fiducials and alignment holes for the stencil and production line. By panelizing myself I make sure the long edges will not be V-grooved, I want them routed for a...
  • Deep Dive: "Shoot-through" Safety Feature
    Sonny Lloyd07/15/2019 at 02:50 0 comments
    “Shoot-through” is the name given to a failure event when two adjacent switches in a voltage source inverter are ON simultaneously thus short-circuiting the supply, as shown in Figure 1. This failure mode can easily become catastrophic especially in motor drive application where the DC link capacity is rather large and has more than enough stored energy to cause a fire if the shoot-through event is not extinguished within a very short time, typically 10µs for a rugged IGBT (other switch technology can be more sensitive and require even faster response times).
                                             Figure 1: Shoot-through Event
    It is interesting to note that the vast majority of the short-circuit current does not come from the traction battery back but rather the inverter’s DC link capacitor which has a very low impedance path between it and the power switches. This means that any current sensor between traction pack and the capacitor will not “see” the fault current and therefore cannot detect the fault. In fact, since there are no current sensors at all in the short-circuit path it makes detecting this type of fault challenging.
    To detect a shoot-through event the gate driver (external to Axiom control board) employs a power switch “desaturation detection” circuit. The gate driver will immediately shut down the local IGBT when a desat fault is detected. When this first IGBT is shutdown the high fault current is extinguished before it becomes catastrophic and the Axiom control board will be notified so that its firmware can work to immediately shut down the other five switches, thus disabling the drive completely. Desaturation detection is a simple circuit, but its simplicity can often be mistaken for simple to design. The circuit must be 100% reliable in a high noise environment, be extremely fast acting and sufficiently stable over a very wide temperature range. Each component in a desaturation detection circuit is carefully considered and the PCB layout is similarly critically analyzed.
    Now that the shoot-through event has been summarized, along with detection and shut down method, the next question is why would a shoot-through event even happen in the first place? Surely the control scheme is such that the processor would never issue ‘ON’ command simultaneously to two adjacent switches. No doubt this is the case.. but for unproven firmware, with well over 100,000 lines of code, its possible that a firmware bug may exist .. and its possible that such a bug could lead to errant command signals. More likely however is that noise from high voltage and high current switching gets coupled back into the control board causing unpredictable erratic behaviour, including causing a shoot-through.
    Since the shoot-through event has the capability to be destructive it is well worth the designers time to invest an effort to prevent, however possible, the mis-firing of PWM signals. Axiom accomplishes this goal in several ways. The microcontroller firmware is based on proven code, used by thousands of users in a wide variety of applications. Despite this, Axiom makes use of an FPGA which monitors the IGBT gating commands to ensure, double ensure that the microcontroller does not issue errant PWM signals.
                                  Figure 2: Overlap Protection Logic Circuit
    The idea of this circuit is to allow the microcontroller to turn on its associated gate driver, either the top or the bottom, but never the top and the bottom simultaneously (shoot-through!).
    The logic truth table is deciphered as:
                           Figure 3: Overlap Protection Logic Circuit Truth Table
    In earlier revisions...
View all 25 project logs
  • 1
    Order parts
    Get an assembled and tested board from www.powerdesigns.ca
    Order components to build a powerstage according to your needs. See the datasheet for examples for 400V 300A operation.
    Need a quicker/simpler/reliable turnaround? You'll be able to order a fully assembled and enclosed motor controller when the beta test stage is done (and jump to stage 3)!
  • 2
    Assemble the motor controller
  • 3
    Connect to the motor and configure the system
    Click on the image, jump to 2:50 to see the motor setup. If you had any past experience with a small VESC controller, its exactly the same!
View all 4 instructions
Chris Helvey wrote 01/06/2020 at 03:38 point
I have scoured the Internet for....THIS! You will get a prize thumbs up from me. I appreciate your work, will be MAKING it, reporting back,  following, cheerleading, and helping change the world a tiny bit at a time. What you are doing is one of the most important projects for open source hardware and software the world needs so badly. We're up against corporate America and they want to sell new cars. THANK YOU!
Kevin wrote 11/20/2019 at 18:57 point
Couple of comments, as we are doing a similar layout for medium voltage with the same IGBTs... You will probably want to nickle plate your bus connections to reduce corrosion, and not sure what your second level power connection spacer material is, but you may want to be careful or considerate of thermal expansion and having your bolt connection torques going all over the map.
To that end, Belleville washers are your friends, use them.
You will probably also want to make some kind of bus support so your cable connections at the end of your diving boards don't blow out the internal connections or crack your upper level board when someone starts wrenching away at the cable connections. Same is true at the capacitor end, you want to have something that indexes your components together so that they move in unison, not as individual elements. Shock and vibration will slowly destroy everything there over time.
Not 100% sure if you'll need IGBT fault detection, because when they go boom, it's taking your control board with it. Ask me how we know.
Sonny Lloyd wrote 11/21/2019 at 02:28 point
Hi Kevin, thanks for the feedback.  i'm definitely aware the copper needs corrosion proofing and bus supports but the bench test units don't have that. there's some things we have to change in the final embodiment and we're working on an enclosure design that will sort of solve those issues.  i have seen capacitors that have mounting stud on the bottom that connects to a tab and the tab is flexible.  sometimes the capacitor with a flat bottom like ours sits on a spongy material.  we're probably going to make the internals rigid and shock mount option the enclosure to frame but our mechanical guy is still working out the details. belleville washers is something we use in industry on all lug connections cable to bus, and is something we intend to use on axiom. the spacer to the 2nd level is your typical threaded metal stand-off. its nothing special other than its repeatable in size, easy to source, cheap .. and conductive.  so we can measure the output voltage right there.  our hardware design is ultra intense on fault protection; my background i have designed gate drivers for military application and fully appreciate what it takes to design them properly.  in endless-sphere i helped another individual design a gate driver for mosfets (much lower power than axiom) but one of the tests he did was just shorted out the output or intentionally caused a shoot-through .. time and time and time again.  no fire, drive just detects and shuts down < 5us.   we have made sure that Axiom has similar fault protection .. i think i wrote a log in this project folder about this subject, you might be interested to read about it.
Gravis wrote 11/05/2019 at 08:38 point
I just looked over your BOM and would like to raise some concerns I have over the temperature range of some components.
== failure before 100°C
ABM3B-8.000MHZ-10-1UT
AD8397ARZ
== failure before 125°C
SN65176BDR
ICE40UP5K-SG48ITR50
BD33HC5MEFJ-ME2
Marcos wrote 11/05/2019 at 09:33 point
thanks for the review! I'll take a look today
Marcos wrote 11/05/2019 at 10:35 point
Oh 60°C max operating temp for the crystal, that's bad and easy yo fix. Thanks, will swap and validate a 125°C crystal next time I order components.
AD8397ARZ may change in the future, its the hottest part of the board so we may use a beefier amplifier stage.
I'm ok with the other temp ratings, control board is not supposed to be operated at more than 85C, that would derate the output power as IGBTs are right below.
Johnny wrote 10/26/2019 at 08:15 point
You guys deserve the hackaday prize. This isn’t so much more needed than people realize and this can have a huge impact on society if people can realize what kindof power you’re helping make readily available to(almost) everyone. This winter I’m hand hammering together Lemans 289 cobra hydrogen roadster and I’m hoping to put your design into my car to control the hydrogen electrolysis on demand.  Will this ever be up on powerdesigns.ca as a board you can buy? When do you think you’ll be beyond testing? I’m waiting Guys. Please sell me a board haha(seriously...)
Sonny Lloyd wrote 10/28/2019 at 01:45 point
Hey Johnny, thanks for the kind words.  Ya we're really excited too.  You figured out how to produce hydrogen on demand in sufficient quantity? If you create the electric spark to at the resonant frequency of the containing medium would that make any difference to overall efficiency? ha. just a crazy idea. just like 100kW+ motor controller once was a crazy idea;  now its real as you have no doubt seen in our customer pages and our own video introduction (https://hackaday.io/project/164932-axiom-100kw-motor-controller/log/167623-video-introduction-axiom-motor-control).  to answer your question, the control board is in BETA test now along with the full up motor drive.  we are expecting to release the product in 2020.  be sure to join our mailing list so you can be the first to find out when that happens.
Johnny wrote 11/02/2019 at 19:04 point
Sonny! Good to hear from you again. Sorry bout the delay it's been a crazy week moving to anchorage, borrowing someone's heated garage to keep building thru this winter, gonna keep tryin not to blow myself up haha excited to show results in a few more months. I've been building everything of recycled appliances/  military surplus parts and everything's been repurposed need to get some control to lower the frequency gonna have to mess with that this winter. I would like to use your board to regulate the electrolysis for this set up... but I have a bigger idea I told you about in a bunch of power design emails that need your boards for too. I'm running a "scariac" for now, its primitive and wooly but its working for now. I'm on the mailing list looking forward to seeing what's next. god I hope I can at least get one board from you round spring. Stay at it Sonny looking forward to all of this.
Tor-Olav Berntzen wrote 10/02/2019 at 14:19 point
Our application requires a pressure of  50bar, under water. The simple way is to place the boards in oil, and allow the pressure to be applied to all components.
Has anybody done this yet?
Marcos wrote 10/05/2019 at 16:24 point
I know it is done for mechanical stuff, but I don't remember seeing this for electronics.
Compromising the high voltage isolation is the main risk here, oil has to provide suitable isolation for safety, and if water gets to enter it will be compromised.
Maybe there is another way, like keeping the controller on the surface, or using lower voltages, or full potting.
t.tirupathi wrote 08/20/2019 at 04:33 point
wow... Amazing project! Can I get gerber files for this board to try it out. Thank you.
Marcos wrote 08/20/2019 at 12:38 point
Hi! Well, I tried selling bare PCBs but no one suceeded assembling them without any quality issue, and a single bad solder joint can compromise the safety of expensive parts, not to mention the risk of life.
The DC link discharge circuit for example, break it and you can get shocked.
Or get 1 component wrong and we'll be spinning in circles forever debugging your drive (I spend a lot of time hand-holding our beta testers!)
So now we only provide fully assembled and fully tested boards.
We have good news though, the full Axiom schematic was released to our newsletter subscribers, soon it will be posted here
t.tirupathi wrote 08/21/2019 at 03:44 point
Thank you for your reply. Where can I purchase the fully assembled and tested boards?
Marcos wrote 08/21/2019 at 12:28 point
Contact us from powerdesigns website if you want to apply to be a beta tester. Cheers
grTavares wrote 05/23/2019 at 19:58 point
Wow... Amazing project! I will try to learn a bit from you.
Piotr Błądek wrote 05/23/2019 at 14:17 point
Good job guys! Only thing Im wondering, is automotive grade of components used, and project as a whole (as far as I remember STM32F4 didn't come with any ISO26262 support, ASILx, or even AECQ100), for DIY EV its not a problem, but for any professional stuff it is. Do you have any plan to support automotive applications with your solution?
Sonny Lloyd wrote 05/23/2019 at 16:00 point
That's an excellent question Piotr, and your observation is correct.  We already have a design, currently in draft, which supports automotive application using  qualified parts and processor (not STM32F4).  It has other features too that Axiom doesn't have, more suitable for that style of customer but it lacks the amazing GUI that VESC has, and also its not open source.
ve2hrj wrote 05/16/2019 at 11:36 point
This is great project, I’m interested to create something like that, but your project is way more advance!
I did notice that you use regular IGBT N-Channel of about ~700A, how about using GaN?
Would it be possible to adapt your board for that?
That would be a very big improvement on efficiency, I think.
Marcos wrote 05/16/2019 at 14:57 point
Gallium Nitride is better suited for lower power applications. GaN technology comes with very low voltage gates (<5V IIRC) and most importantly a lack of high current off the shelf modules. Also they are normally-closed devices, you really don't want that in a high power half bridge. You wont find a 500A GaN because parasitics would turn itself on.
GaN is not the only wide bandgap technology out there, we have Silicon Carbide that has large gate voltage threshold for better tolerance against Miller self turn-on (which gets much worse at high dV/dt), its normally open, and industry has been making SiC modules for quite a long time now.
Having said so, we carefully chose our parts and design rules so Axiom can manage next-gen devices like Silicon Carbide that make for more compact and more efficent drive units. Basically by minimizing capacitive coupling between high voltage and control logic domains.
arbydarby wrote 04/20/2019 at 01:18 point
this needs to win, fabulous
c.Invent wrote 04/19/2019 at 17:09 point
Let me just say this: this project is nothing short of amazing and I honestly think it deserves to win.
Maxi wrote 04/19/2019 at 21:49 point
Thanks for your support
Sonny Lloyd wrote 04/16/2019 at 02:09 point
Yes you're right Zachary.  There's a lot a platform like this can do and its not that far from a perfect match to the other application you're brainstorming.  Of course, being open source, YOU have all the power to make the changes you want to see  :)
Zachary Drew wrote 04/16/2019 at 04:24 point
I do, I will, and this is what's so exciting to me about stuff like this! I keep seeing this pattern in technology repeating itself over and over again. Things are a little too purpose built, usually for good reason, but as technology improves those reasons disappear. Look at the disconnect between e-bike and e-board motor controllers. It's my impression VESC hasn't taken off with e-bikes because of the 60V limit imposed by the TI DRV8301. Now TI just came out with the 100V DRV8350 so the source of that disconnect seems to be going away.
Another place I see this is in HVAC. Need a big system? Build a big system. Need a small system? Build a small system. Need AC? Install an air conditioner. Need heat? Install a heater. Except they are all (or should be) doing the same thing: transferring heat from one place to another and the most efficient way to do that with electricity is the heat pump which are reversible with a single reversing valve. Now we go fractal: The heat pump guys will then ask you if you doing air-to-water, air-to-air, air-to-ground, etc... and I just want to scream "is it too much to ask to design a plate-to-plate, modular sized heat pump, mass produce them in obscene numbers so they are cheap, if I have a big system I will use a lot of them, if I have a small system I will only use one?" And now we'll go ouroboros: The compressor will be designed for your specific grid (110V/220V, 50hz/60hz) even though modulating DC inverting compressors are the clear path forward (ha, we're back to motor controllers again!) Next will come the question of the alphanumeric soup of refrigerants to which again there is a very clear answer: CO2 except the R&D for that has been weirdly slow across all these fiefdoms of HVAC. Sure, it's harder to run refrigerant at several thousand PSI but guess what? It eliminates many of the sources of all these little disconnects, and the components are dramatically smaller and ultimately cheaper. Now instead CO2 refrigerant has made great inroads into retail commercial refrigeration. DC inverting compressors are the norm in mini-splits. But want a window unit with a DC inverting CO2 compressor? Guy at the bigbox store: how about this 80 pound window unit that hasn't had a design update since 1998 except for when the face-plate injection mold tooling wore out nine years ago so they gave the model a facelift,  and five years ago, when blue LEDs got cheap so they changed the LCD backlight color to "good luck sleeping with this blinding blue LED shining in your face, while this ancient compressor cycles on and off to hit the temperature set point, while your back hurts from installing it in the window, and, oh, sorry about the larger-than-necessary electrical bill coming next month, and sorry to your kids when the refrigerant leaks out because it has a global warming potential 1000x worse than CO2, but hey, exotic patented synthetic refrigerants are big business."
My apologies for that rant, it's been building up for a while.
Sonny Lloyd wrote 04/16/2019 at 14:20 point
no worries, we feel the same.  its why our product exists, to allow for some flexibility as needed!  by the way, we have a motor controller based on the 100V DRV8350 chipset though it hasn't been published (yet).  It was meant for 1 to 10kW systems in high G-Force application.
Zachary Drew wrote 04/15/2019 at 21:54 point
This is incredible work! This feels exactly like what's needed for VESC to take over the DIY EV world and beyond. For example, if a DIYer wanted to heat a cold battery pack using the motor/inverter ala the Tesla Model 3 method this should allow that! Going even further, with some added components I believe this could allow the motor inverter and IGBTs to pull double duty as a pure sine wave inverter. Park the vehicle, switch the inverter from traction mode to inverter mode and you've got a huge power wall on wheels.
The u.FL connectors for simulation-quality in-circuit measurements and the FPGA shoot-through protection is brilliant!
Marcos wrote 04/16/2019 at 02:28 point
Thanks! You can artificially heat up the drive unit by setting an Id current (it doesn't produce any torque), its a simple command,
You need some contactors and an inductor/transformer + filtering to smooth the 3 phase voltage in order to supply a house. But as far as the board is concerned its 1 command away as well, it was added recently!
Zachary Drew wrote 04/16/2019 at 03:19 point
Usually a big inductor too! Though I have been wondering if there are specific DC/AC voltage ratios to minimize the cost, weight, and conversion inefficiencies. And maybe it could go the other way, is there a specific voltage ratio to maximize charging efficiency? Imagine if a single piece of hardware could be the motor driver, DC charger, and vehicle to grid energy controller. I'm only slowly beginning to understand how all these things works and I keep seeing similarities... everything is just some kind of inverter which has left me wondering if it's just lack of imagination that is holding back the convergence of these technologies or if there is a specific first-principles reason that prevents it.
Nicholas DiVitto wrote 04/15/2019 at 20:33 point
Wow! Simply beautiful, and definitely what the DIY EV community needs. Is there induction motor support, or just BLDC?
Marcos wrote 04/16/2019 at 02:08 point
It can make an ACIM spin, there are commands to generate a fixed frequency 3 phase.
Full Field Oriented Control of ACIM is in the TODO list, should happen soon! It would need a small tweak of the control loop and a new phase observer.
Sonny Lloyd wrote 04/16/2019 at 02:15 point
I should add that we are REALLY motivated and excited to explore the parameter detection methods that make ACIM possible because if you're willing/capable of rewinding the motor yourself to better match your EV battery you can save a LOT of money and end up with a pretty decent performing motor.  that's a real plus for extreme DIY'ers like you and me.  I know.. industrial motor's don't lend themselves well to EV application.. but .. if the old motor is selected properly, rewound yourself with intention .. i think you'd be surprised what you can get out of it for a fraction of the cost :)
Nicholas DiVitto wrote 04/16/2019 at 12:47 point
Awesome! I've been following this project for a little while and its really cool to see how it has matured. Keep up the great work!
