EyeSkillsbrille-schnittmuster.svgThe neoprene/foam cutout to make even Google Cardboard comfortable for any sized head!svg+xml - 12.63 kB - 04/12/2019 at 11:55 |
EyeTracktiveParts.pngA quick look at the parts you print/cut to form the basic unitPortable Network Graphics (PNG) - 125.37 kB - 04/12/2019 at 11:54 |
CardboardCore.scadThe foldable insert which holds everythingscad - 9.42 kB - 04/12/2019 at 11:54 |
CameraHolder.scadA 3D printed camera mount for the guts of small, cheap endoscopic cameras.scad - 4.16 kB - 04/12/2019 at 11:54 |
lensRemovalTool.scadA tool to help you remove the IR filter from camera modulesscad - 117.00 bytes - 04/12/2019 at 11:54 |
InstallationHelper.scadA tool to help you insert the camera holder quickly and correctlyscad - 659.00 bytes - 04/12/2019 at 11:54 |
EyeTractiveParts.scadThe OpenSCAD file which brings all the modules together!scad - 877.00 bytes - 04/12/2019 at 11:54 |
