Here it is. Resistor connected to ground directly this time!
First of all I noticed stronger magnetic field, as well - low-frequency oscillations. I was happy about that and that is what I've seen on gates of MOSFETS:
196Hz square wave, Nice! As predicted, everything was great on I_COIL input too:
Then I felt very frustrated, I realized what reference voltages (which should affect energy boundaries) unable to change behaviour of board much. And then I discovered that:
