Well, lazy me soldered high side MOSFET driver yesterday, in replace of strange IR2117 (probably, burned)
Now it use three transistors instead of IC, it gives bug-fix freedom. Happily, it worked "right from the box", transistor opens as needed, as bootstrap capacitor sends needed amount of voltage to drain. Yes, I cannot feel any heat, so I would return to surface-mount housings instead of heavy-lifters like TO-247 (however I like them, ahaha) - but it's not the interesting part! Interesting part!
Now I have fully-working electromagnet driver, and I've made some test. Results were kind of intriguing. First of all, I found, that you can maintain semi-constant current on coil, it wouldn't affect efficiency. As you can see, current is quite stable. I'm not sure if I can achieve greater efficiency by increasing amount of withdrawn energy. So we can forget about kind of PWMed magnetic field! Hooray!
But question of efficiency remains unsolved for now:
