Learn How to Make a Printed Circuit Board at home using the Iron & Laser Printer method and Ferric Chloride Etchant.
Don't forget to Subscribe for more projects: YouTube
Once you have finished designing the board layout of your circuit in Eagle, go to Layer Settings and select Hide Layers.
Next, select only the following layers for a bottom layer only PCB:
Then go to File>Print. Set the Printer to Microsoft Print to PDF.
Ensure that the following settings are also selected: Black and Caption.
Click OK and Save the file in the destination folder of your choice.
View all 10 instructions
fl@C@
KSUdoubleE
Walt Perko
George I Fomitchev
Yes, delete it Cancel
You are about to report the project "DIY PCB Etching", please tell us the reason.
