PCB Design
A project log for Gesture FeatherWing
A daughterboard with a capacitive gesture sensor for the Adafruit Feather boards.
dehipudeʃhipu 11/01/2019 at 19:520 Comments
To avoid paying extra for two PCB designs, both layers of the sandwich are connected at the corner — they have to be cut manually for assembly.
The design above has the copper fills removed for clarity. The antenna pretty much follows the recommendations from the datasheet. The traces going to it are kept as short as possible.
To avoid puncturing the ground layer, the connector for the Feather is made out of an angled male header, soldered SMD-style to the board. In a final design, a proper SMD header could be used instead.
