Macr - Oh $#it
A project log for Grinder Minder
Bench Grinders are everywhere. So are fingers. May the two never meet. That's where grinder minder comes in.
scott-swaaleyScott Swaaley 07/29/2019 at 17:380 Comments
Since our sharp left turn last month, we've been heads down working out a prototype. We took advantage of the awesome folks at MacroFab and had a PCB made. Then ... of course ... we realized the mistakes we made on layout and had to hack it a bit (well, a lot). This is how it looked going into our first test.
Big picture - this PCB contains a few parts.
  1. High-voltage high-power AC: big fat relays, big fat traces (2oz / 3mm), and lots of nothing (large spacing) to prevent arcing or shock.
  2. High-voltage high-power DC: we're testing some ideas for a high-power-density DC source (see previous post). You definitely don't want to touch this part
  3. Low voltage controls: galvanic isolation is a big deal so we've isolated all low-voltage stuffs and kept it simple. Digital controls but it's all logic - so software or firmware.
Next it's time to turn it on!
