Prototype_Enclosure_Body.stlThe 'walls' of the prototype enclosure. Standard STL mm format. CC BY 4.0Standard Tesselated Geometry - 65.02 kB - 08/15/2019 at 21:22 |
Prototype_Enclosure_Assembly.rsdocThe assembly of the prototype enclosure. Created in Design Spark Mechanical. CC BY 4.0rsdoc - 893.43 kB - 08/15/2019 at 21:21 |
Prototype_Enclosure_Mount Plate.stlThe mounting plate for the circuit board. Standard STL mm format. CC BY 4.0Standard Tesselated Geometry - 280.55 kB - 08/15/2019 at 21:21 |
Prototype_Enclosure_Graphic.svgThe top surface of the prototype enclosure. Designed to be cut/engraved on a laser cutter. Best edited in InkScape. CC BY 4.0svg+xml - 14.37 kB - 08/15/2019 at 21:20 |
Enclosure Matrix.xlsxCC BY 4.0sheet - 17.80 kB - 08/14/2019 at 16:37 |
Megunolink.inoThis is two of two arduino sketches that interface with the MCP39F511A eval board and the MegunoLink interface. CC BY 4.0ino - 5.07 kB - 05/13/2019 at 16:11 |
Power_Monitor_Fast.inoThis is one of two arduino sketches that interface with the MCP39F511A eval board and the MegunoLink interface. CC BY 4.0ino - 13.26 kB - 05/13/2019 at 16:11 |
Power Monitor.mlpzThis is the Megunolink project that we use to run our MCP39F511A power monitor. CC BY 4.0mlpz - 30.20 kB - 05/13/2019 at 16:10 |
