Fabricating the PCB
A project log for Solar Powered WiFi Weather Station V2.0
A solar-powered ESP8266 based Weather Station, which can run years without taking power from an external source
Debasish DuttaDebasish Dutta 04/18/2019 at 09:520 Comments
After designing the PCB, I have exported the PCB design files known as Gerber files which are used to manufacturing the PCB.
You can order it from PCBWay .
Note : When you place an order, I will get 10% donation from PCBWay for contribution to my work. Your little help may encourage me to do more awesome work in the future. Thank you for your cooperation.
