Uploading Sensor Data to ThingSpeak
A project log for Solar Powered WiFi Weather Station V2.0
A solar-powered ESP8266 based Weather Station, which can run years without taking power from an external source
open-green-energyOpen Green Energy 04/19/2019 at 06:310 Comments
First create an account on ThingSpeak.
Then create a new Channel on your ThingSpeak account.
Find How to Create a New Channel Fill Field 1 as Pressure ,Field 2 as Temperature, Field 3 asHumidity,Field 4 as altitude and Field 5 as Bat Voltage.
In your ThingSpeak account select “Channel” and then “My Channel”.
Click on your channel name.
Click on “API Keys” tab and copy the “Write API Key”
Open the Solar_Weather_Station_ThingSpeak code .
Replace the “WRITE API ”with the copied “Write API Key”.
You can see my live feed.
Currently, I am getting an inconsistent reading for battery voltage, so the field is disabled.
