UV Sense Daily UV Dosage Tracker
A dosage tracker for your daily UV exposure. With features like Dynamic algorithm and mobile notifications over Bluetooth
Public Chat
More coming soon
Arduino_Code_UVSense_MINI.zip
Zip Archive - 8.54 kB - 04/18/2019 at 23:42
Download
uvsense board.sch
sch - 165.28 kB - 04/18/2019 at 23:41
Download
  • 1 × Aduino Nano 3.3v
  • 1 × UV Senor Module ML8511 Uv Sensor
  • 1 × USB LiIon/LiPoly charger - v1.2
  • 1 × 50mah Battery Battery
  • 1 × Bluetooth Module BT-06 both work Connectors and Accessories / Board Stacking Connectors
hackaday wrote 03/30/2020 at 13:06 point
I've done a few UVI projects myself. The problem I found with wearables is their orientation to the sun changes the UVI reading enough to make them useless. Pretty much you have to put it on the top of your hat, like you show yourself in one of your photos. Based on feedback, the most 'useful' one I did was a tiny fob that just blinks out the UVI on a very bright green LED. I was able to get the BOM cost down below $5 in small quantities by using a UVA LED as the photosensor, vs the Roitner Technik GUVA-S12, which is about $5 by itself.
If you could make it a $5 retail item that costs $1 or $2 to build, you might have a decent product that could sell in tourist shops in beach towns. Surely moms with little children might buy one while checking out with the suntan lotion. Or perhaps convince a skincare manufacturer to use it as a promo or pack-in item. I haven't had time to pursue that yet.
Here's an old blog of my experiments: https://www.matrixwide.com/wp/
