• Using ezx display with dxfout.h
    agp.cooper • 04/26/2019 at 09:07 • 0 comments
    Graphical Display Libraries
    I used to use one of the "BGI" graphics libraries. A port of the old Borland BGI graphics library. I had a version for Linux and Windows. It's okay but I migrated to "ezxdisp" (http://morihit.net/ezxdisp/) because it was faster and had some useful features. Neither of the libraries will display images.
    However, many people still use Windows and porting back to windows and using BGI library is inconvenient. Initially I had a little trouble compiling the Win32 "ezxdisp" library but if you read the "ezxdisp" webpage they point you to how to do it. Install "msys" and use that. Had a little trouble with setting up "msys" but that may have been because my hard disk was almost full.
    Anyway, the Win32 (MinGW) library has been compiled and uploaded to my files area.
    Compiling an "ezxdisp" Application
    The main thing is to install the header and library in your preferred location.
    Either /usr/include and /usr/lib for Linux, or /MinGW/include and /MinGW/lib for Windows (assuming your using MinGW).
    If you really want to you can just copy the files into you code working directory, but remember to tell the compiler and linker to look in the work directory.
    Linker Settings
    This is perhaps the most import thing to know. I usually put a comment to remind me in the source code.
    For Linux the linker settings are:
    • -lezx -lX11 -lm
    For Win32 (MinGW) it is:
    • -lmingw32 -lezx -mwindows
    Here is a code snippet on using "ezxdisp":
    #include <stdio.h>
    #include "ezxdisp.h"
    int main(int argc, char *argv[])
      ezx_t *e;
      e = ezx_init(200, 200, "no title");
      ezx_set_background(e, &ezx_white);
      ezx_fillcircle_2d(e, 100, 100, 40, &ezx_red);
      ezx_redraw(e);
      ezx_pushbutton(e, NULL, NULL);
      ezx_quit(e);
      return 0;
    Editing the DXFOut demo to show what it is writing to file.
    // Include Libraries
    #include <stdio.h>
    #include <stdlib.h>
    // Please check dxfout.h for function parameter definitions
    #include "dxfout.h"
    // -lezx -lX11 -lm             for Linux
    // -lmingw32 -lezx -mwindows   for windows (MinGW)
    // EZX display structure
    ezx_t *disp;
    // EZX window size
    int width=1200;
    int height=700;
    // Nominal display scale
    double scale=10.0;
    int main(int argc,char **argv) {
      printf("DXFOut V1.1 - Written by Alan Cooper (AlanCooper@StartMail.com)\n");
      // Open a new DXF file
      char fileName[128];
      sprintf(fileName,"DXFOutTest.dxf");
      FILE *F1=fopen(fileName,"w");
      // Initialise graphics
      disp=ezx_init(width,height,"Show DXF");
      ezx_set_background(disp,&ezx_black);
      // Create a small box:
      //   Use Shape (closed polyline)
      //   Set Colour 0
      //   Set Layer "Test"
      //   Note: Z coordinate is 0
      DXF_Begin(F1);                        // Required once
      DXF_ShapeBegin(F1,"Test",0);          // Required for each shape (closed polyline)
      DXF_ShapePoint(F1,10,30,0);
      DXF_ShapePoint(F1,30,30,0);
      ezx_line_2d(disp,width/2+scale*10,height/2-scale*30,width/2+scale*30,height/2-scale*30,&ezx_white,1);
      DXF_ShapePoint(F1,30,10,0);
      ezx_line_2d(disp,width/2+scale*30,height/2-scale*30,width/2+scale*30,height/2-scale*10,&ezx_white,1);
      DXF_ShapePoint(F1,10,10,0);
      ezx_line_2d(disp,width/2+scale*30,height/2-scale*10,width/2+scale*10,height/2-scale*10,&ezx_white,1);
      ezx_line_2d(disp,width/2+scale*10,height/2-scale*10,width/2+scale*10,height/2-scale*30,&ezx_white,1);
      DXF_ShapeEnd(F1);                     // Required for each shape (closed polyline)
      // Put a point in the middle
      DXF_Point(F1,"Test",1,20,20,0);
      ezx_point_2d(disp,width/2+scale*(20),height/2-scale*(20),&ezx_red);
      // Make point look like a cross-hair using lines
      DXF_Line(F1,"Test",2,22,20,0,25,20,0);
      ezx_line_2d(disp,width/2+scale*22,height/2-scale*20,width/2+scale*25,height/2-scale*20,&ezx_yellow,1);
      DXF_Line(F1,"Test",2,18,20,0,15,20,0);
      ezx_line_2d(disp,width/2+scale*18,height/2-scale*20,width/2+scale*15,height/2-scale*20,&ezx_yellow,1);
      DXF_Line(F1,"Test",2,20,22,0,20,25,0);
      ezx_line_2d(disp,width/2+scale*20,height/2-scale*22,width/2+scale*20,height/2-scale*25,&ezx_yellow,1);
      DXF_Line(F1,"Test",2,20,18,0,20,15,0);
     ezx_line_2d(disp,width/...
  • Using the Library
    agp.cooper • 04/19/2019 at 10:46 • 0 comments
    Using the Library
    First copy the header file (dxfout.h) into your project folder.
    Next, add the line #include "dxfout.h" to your program (near the top, perhaps just below the system file headers).
    Here is an example (dxfoutTest.c):
    / Include Libraries
    #include <stdio.h>
    #include <stdlib.h>
    #include "dxfout.h"
      printf("DXFOut V1.0 - Written by Alan Cooper (AlanCooper@StartMail.com)\n");
      char fileName[128];
      //   Set Colour 0
      //   Set Layer "Test"
      // Put a circle around the cross-hair
      DXF_Circle(F1,"Test",3,20,20,0,5);
      // And another box but using polyline (open polyline)
      DXF_PolylineBegin(F1,"Test",4); // Required for each shape (closed polyline)
      DXF_PolylinePoint(F1, 9,31,0);
      DXF_PolylinePoint(F1,31,31,0);
      DXF_PolylinePoint(F1,31, 9,0);
      DXF_PolylinePoint(F1, 9, 9,0);
      DXF_PolylinePoint(F1, 9,31,0);  // Close the box
      DXF_PolylineEnd(F1);            // Required for each shape (closed polyline)
      DXF_End(F1);                    // Required once
      // Close the DXF file
      fclose(F1);
      return 0;
    And here is the output in a CAD package:
    Before you accept that it has worked, check that the boxes and the circle are in fact one polyline and not multiple lines (i.e. individual segments).
    Next
    For my next post I will look at adding graphical output to the test program.
    AlanX
