CJ_customized_parts.scadOpenscad source file for WheelHub, LX16 Coupler, and Differential Link. Each part has a slot for an M3 nut instead of using a threaded insert. I recommend printing each at 95% for extra strength.scad - 2.42 kB - 01/08/2023 at 20:05 |
WheelHub with slot.stlThis part has a slot for an M3 nut instead of using a threaded insert.Standard Tesselated Geometry - 368.40 kB - 03/28/2020 at 09:21 |
Steering Knuckle with slot.stlThis part has a slot for an M3 nut instead of using a threaded insert. Also has a chennel for routing the wiring.Standard Tesselated Geometry - 1.01 MB - 03/28/2020 at 09:14 |
diff_link.stlThis part has a slot for an M3 nut instead of using a threaded insert.Standard Tesselated Geometry - 1.80 MB - 03/28/2020 at 08:25 |
R2D2.wavR2D2 sound file for CJWaveform Audio File Format (WAV) - 90.62 kB - 07/21/2019 at 20:35 |
snowblwr.mp3Short Circuit sound file for CJmp3 - 66.39 kB - 07/21/2019 at 20:35 |
cantdo.mp32001 sound file for CJmp3 - 39.35 kB - 07/21/2019 at 20:35 |
LX16 Coupler.stlThis part has a slot for an M3 nut instead of using a threaded insert.Standard Tesselated Geometry - 395.70 kB - 06/20/2019 at 02:33 |
