vm02.rarFull offline versionRAR Archive - 4.83 kB - 05/25/2019 at 10:56 |
vm01.rarHardware test codeRAR Archive - 3.12 kB - 04/22/2019 at 13:46 |
Vending Machine v102.f3dFusion 360 filefusion - 19.55 kB - 04/21/2019 at 18:55 |
Vending machine shield_2019-03-28.zipGerber file, ready to manufacture the PCB. File tested and 100% functional.x-zip-compressed - 315.90 kB - 04/21/2019 at 18:51 |
6mm-mdf-pg1.svgVector file compatible to Inkscape from 6mm mdf cuts, pg1. Sheet size is 40x80cmsvg+xml - 63.39 kB - 04/21/2019 at 18:46 |
3mm-clean.svgVector file compatible to Inkscape from 2.8mm acrylic cuts. Sheet size is 40x80cmsvg+xml - 52.37 kB - 04/21/2019 at 18:46 |
3mm-mdf.svgVector file compatible to Inkscape from 3mm mdf cuts. Sheet size is 40x80cmsvg+xml - 43.82 kB - 04/21/2019 at 18:46 |
6mm-mdf-pg2.pdfPdf file from 6mm mdf cuts, pg2. Sheet size is 40x80cmAdobe Portable Document Format - 1.81 kB - 04/21/2019 at 18:46 |
6mm-mdf-pg2.svgVector file compatible to Inkscape from 6mm mdf cuts, pg2. Sheet size is 40x80cmsvg+xml - 16.10 kB - 04/21/2019 at 18:46 |
6mm-mdf-pg1.pdfPdf file from 6mm mdf cuts, pg1. Sheet size is 40x80cmAdobe Portable Document Format - 4.74 kB - 04/21/2019 at 18:46 |
3mm-mdf.pdfPdf file from 3mm mdf cuts. Sheet size is 40x80cmAdobe Portable Document Format - 4.74 kB - 04/21/2019 at 18:46 |
3mm-clean.pdfPdf file from 2.8mm Arylic cuts. Sheet size is 40x80cmAdobe Portable Document Format - 2.55 kB - 04/21/2019 at 18:46 |
Vending machine shield.pdfPdf schematics fileAdobe Portable Document Format - 49.57 kB - 04/21/2019 at 18:45 |
Vending machine shield.schEagle schematics filesch - 1.05 MB - 04/21/2019 at 18:43 |
Vending machine shield.brdEagle board filebrd - 207.63 kB - 04/21/2019 at 18:43 |
