SquirclePad is a simple nine key macropad. Each keys behaviour is fully customisable using the QMK firmware. Features RGB underlighting, compatible with Cherry MX (or clone) switches, and uses a Pro Micro dev board as its controller for easy assembly. Enclosure will be 3D printable and will (maybe) include lasercut acrylic panels for the base and top plate.
This project was started this as a first excercise in PCB design and SMD soldering. Probably will be the most horrifying board you'll ever see.
