PCB time!
A project log for VAIO Palmtop PC mSATA SSD upgrade
In the quest for upgrades and 'future proofing' I will attempt to squish an mSATA SSD into a Vaio palmtop where nature never intended.
nfmNFM 05/21/2019 at 15:550 Comments
PCB is all laid out! I got it just under 2 square inches which is nice.
I beeped out the connector on the Vaio flex cable and wired my flex adapter so match on the motherboard end, and match a 40-pin ZIF socket on the other.
All the connections are length matched to within +/- 0.1mm too for fun and signal integrity.
