Enlightened-Otter
The worklight for hacker events
I'm a regular visitor at most German hacker events and while I enjoy the lounges and talking to people, I also want to do some hardware projects while I'm there. However, soldering and working on hardware in low light is a difficult task: Most hacker events do have colorful, but not very bright lightning. That's why I've build Enlightened Otter. In short, Enlightened Otter is a mobile battery powered working light that can be screwed onto the most available resource at such events, empty Club Mate bottle. It is based upon a STM32 with the regulator for the dual boost converter running in software. The main goal is to provide cableless, high CRI, high brightness, flicker-free illumination with a variable color temperature. The PCB also features USB-C (power profile 1) to deliver enough power to charge the 18650 type batteries, while supplying bright light.
Enlightened-Otter V1.0 demo:
Very helpful @emfcamp :) https://hackaday.io/project/160642-ottercar
  • 1 × Enlightened Otter Main PCB + LED PCB
  • 1 × Club Mate Bottle
  • 2 × 18650 Battery Choose capacity over power
  • 1 × 3D Printed insert
  • Feature list for V2
    Jana Marie • 05/08/2019 at 17:35 • 0 comments
    Version V1.1 is now finished, but I am not happy yet. Since I want to change a few things to have Enlightened Otter as a finished, robust "product", I want to build a second version. :)
    The following features should be added/changed:
    • Move all parts to the bottom side of the PCB
    • Change battery clips from THT to SMD
    • Add fuses
    • Remove ground-plane around the touch-pads
    • Better power plane splitting
    • Change ESP footprint to a smaller one
    • Add moodlight leds
    @Jan pointed out, that I could use silicone bottle caps instead of a 3D printed thread. I really like that idea so I ordered different models from aliexpress. Most promising cap/plug is the following one:
  • Measurement of light output
    Jana Marie • 04/24/2019 at 11:01 • 0 comments
    With a luxmeter I measured the light output of Enlightened Otter at a color temperature 3500 K and 6500 K, the resulting brightnesses are 1600 lx and 2000 lx. I'm quite happy with that, for comparison, recommended minimum brightness desk lighting is 800 lx.
    I used the values to create the following specification table:
    Iout (per channel)0-500mA
    Vout (per channel)0-18.5V
    Pout (per channel)0-7.5W
    Illuminance (3500k @400mA)1600lx
    Illuminance (6500k @400mA)2000lx
    Vin (USB)4.8-14V
    Iin (USB)3A (max)
    Vbat3.8V
    Ibat (max)5A
    Boost frequency500kHz
    Iripple (@2.5kHz)<0.5mA
  • Enlightened Otter V1.0/V1.1
    Jana Marie • 04/24/2019 at 10:36 • 0 comments
    With the boards from the previous two Logs we can already assemble an Enlightened Otter. There is not much to that: Snap in two batteries, add the 3D printed part, add insulators, add nuts and you're done.
    The software is written in C with the STM32 HAL Lib and Makefiles. The difficult part here is the hardware initialization, since most of it runs offloaded from the CPU using HRTIM triggered ADC.
    All the bodges of V1.0 where removed in V1.1. A major problem both versions have, is ghost touch input from boost converter noise. This can be solved by lowering the sensitivity, but then the input is no longer so responsive.
    The charging of the batteries and the battery operation function perfectly. Also the Boost converter works very well, but the Mosfets get very warm, in version 2.0 a new package has to be chosen. The current measurement and the controller have no problems, a current control with a current ripple of < 0.5mA is possible.
    The protective devices trip in the event of a fault.
    On the board I have provided a footprint for an ESP, but I haven't equipped and tested it yet
    The full Enlightened Otter V1.1 design can be found on Github, I will add the Source files as soon as possible.
  • Main PCB V1.0/V1.1
    Jana Marie • 04/24/2019 at 09:31 • 0 comments
    To drive the LEDs, we need two boost converters from VBAT (3.2V-4.2V) to VLED (~10V-16V). Since I want to keep the costs as well as the number of components low, I decided for a processor, which can implement the Boost converter in software.
    The STM32F334 has a timer with a clock frequency of 4.6Ghz*, comparator inputs, reasonable ADCs and a touch controller. So I get PWM at 500kHz with a resolution of >13 bit. The ADCs are needed to regulate the LED current via the boost, the comparators are used to stop the boost in a fault condition in shortest time without software interaction.
    A schematic can be found here.
    I want to use the Touch controller (TSC) for the input of Enlightened Otter. Beside a slider I need three buttons (on/off, brightness, color temperature). This allows you to distinguish between brightness and color temperature and adjust them with the slider. To save pins I implemented a resisitive interpolation of the touch slider. Thus three pins result in a slider with a resolution of > 300 points (measured). Atmel has a good application note on this topic. Unfortunately the interpolation resistors are a source of error if you touch them, so I put a solder resist mask as insulation/protective lacquer on them.
    PCB-Touch is a quite neat input method, cheap and easy
    * Of course the STM doesn't have a 4.6Ghz clock, but 32 144Mhz clocks with phase-shifted timers.
    On the backside of the PCB spacers are soldered as SMD to connect both PCBs, so I don't have screw holes on the topside. Unfortunately this is also rather fiddly, spacers tend to fall over when soldering.
    As battery connector I used "Keystone 54", they have the smallest footprint available for 18650 type cells.
  • LED PCB
    Jana Marie • 04/23/2019 at 19:59 • 0 comments
    An approximate estimation showed that with about 25 LEDs I could achieve an adequate brightness for working. So 50 LEDs have to be on one PCB, 25 of each colour. An arrangement of 5*5 LEDs (5 in series, 5 rows in parallel each) is recommended, so we get a voltage of ~16V at a current of ~500mA per color.To dissipate the waste heat from the LEDs we need an aluminium core board.
    The creation of the layout is a little fiddly, because with an aluminum core PCB a second layer is very expensive. Single layer aluminium core boards cost only about 1.5€ per 100*100mm per piece at 15 pcs. To cross tracks you have to use zero ohm resistors. However, since we only need a few components in a simple sample, this should not be a problem. In addition to the LEDs an NTC is used to measure the board temperature.
    LED-PCB + Spacer
    Since we want to make the connection between the boards with spacers and an aluminium PCB is made of aluminium from behind, we have to insert an insulation here. Fortunately, spacers and FET-screw-insulators have the same diameter.
  • Basic Design
    Jana Marie • 04/22/2019 at 16:41 • 0 comments
    The idea for the mechanical design was already born at the GPN. Since lamp holders and feet are unnecessary balast during transport, I first looked for a replacement for them. A Resurce that is available on every event are empty bottles, especially Club Mate bottles. So I want to use an empty mate bottle as a base.
    Another advantage that came up later, is that a mate bottle with a lamp on top is always below eye level and therefore does not dazzle.
    With a bottle as the base, a round "UFO"-like design with batteries between the LEDs and the main board is obvious. Since the LEDs have to dissipate some energy/heat, I will have to use an aluminiumcore pcb for the LED board. Another thing to keep in mind is, that a thread for the bottle is needed, it will be 3D-printed and needs a matching hole. Such a circuit board is not available at AliExpress, so I have to design it myself.
    All other components will find their place on the main pcb. This includes a STM32f334 as processor and a RT9466. I chose the STM32f334 because it has a 4.6Ghz timer which can be used for PWM. Also the processor has hardware comparators which can stop the timer in case of emergency (e.g. short circuit, overvoltage) and a touch controller. I want to use a PCB touch slider as well as touch buttons for control of Enlightened Otter.
    The RT9466 is a highly integrated battery management IC often used in smartphones. I want to use it because of the power path and the shipping mode feature. Especially the shipping mode feature allows me to store Enlightened Otter when not in use for long time.
    As I want to store two 18650 type Batteries in between the two PCBs, I have to find a way to connect both boards while having enough space. I am thinking about soldering pcb-spacer screws to the main board.
    With all that settled I can start with prototyping.
  • Inspiration
    Jana Marie • 04/22/2019 at 16:25 • 0 comments
    I was inspired to do this project by Thunfisch at the GPN18.  He brought a 10*10 px LED matrix to the event, which was used instead of RGB LEDs with WW,CW and Amber leds.
    Of course, I have not only equipped my matrix with white LEDs ;)
    I thought the idea of my own little working light was pretty cool, so I collected what features I need. The summary is:
    • Small footprint, lightweight
    • High CRI
    • Flicker-free
    • Battery operation
    • Easy to operate
    • Colour temperature adjustable
    That was the point where I started Enlightened Otter.
View all 7 project logs
morgan wrote 05/06/2019 at 21:36 • point
Very important question. Is this beer bottle compatible?
Jana Marie wrote 05/06/2019 at 21:40 • point
Yes and no. Not the one on the pictures, but the insert is 3D printed, one could make it beer bottle compatible ( I usually don't drink beer D: ).
Jan wrote 05/07/2019 at 04:32 • point
Could some press fit insert be the solution to make it more universal? That thing is awesome! Would be even cooler if it fitted a few bottles from the start!
Jana Marie wrote 05/07/2019 at 13:45 • point
Hey @Jan
Thanks, that is a good idea, I will try that! :)
Jan wrote 05/07/2019 at 18:02 • point
Something like this: https://www.pfannen-joschi.de/kuechenhelfer/haushaltshelfer/1117/silikon-flaschenverschluss I guess printed but with room to compress (slits or so) would work!
Jana Marie wrote 05/07/2019 at 19:57 • point
@Jan That is a great idea! :O But i will go for this model, its much easier to use and fits perfectly into my existing CAD. https://www.aliexpress.com/item/2018-Kitchen-Anti-lost-Silicone-Hanging-Button-Seasoning-Beer-Wine-Cork-Stopper-Plug-Bottle-Cap-Cover/32911076829.html
Jan wrote 05/08/2019 at 07:41 • point
@Jan--Henrik yeah, those you found at aliexpress seem very easy to replicate and insert into your design!
Mike Szczys wrote 05/06/2019 at 19:53 • point
Ha! Love it... this one's going in the newsletter for sure ;-)
Jana Marie wrote 05/06/2019 at 21:38 • point
Thanks! :3
