Do cheap components make a difference?
A project log for Precision Voltage and Current Reference
A little something to check your digital multimeter accuracy occasionally.
bud-bennettBud Bennett 08/28/2019 at 19:550 Comments
I decided to make another voltage reference, this time using the cheapest components that I could find on eBay or Aliexpress. I even ordered the enclosure from an Asian source. Here are the results after more than 1000hrs.
2019-07-14 after running for 2 hours at temperature
Meter params: HighZ, 100PLC, AZ on
Value Range
100.0004mV 100mV
1.000007V 1V
2.50014V 10V
9.9999995V 10V (last digit bouncing)
2019-07-21 after running for 168 hours at temperature
Value Range
99.9912mV 100mV
1.000014V 1V
2.50001V 10V
10.00008V 10V
2019-08-28 1096 hrs:
Value Range
99.9925mV 100mV  (79ppm)
0.999978V 1V (36ppm)
2.49998V 10V (64ppm)
10.00021V 10V  (21ppm)
There doesn't appear to be any significant difference.
