<a target="_blank" rel="noopener noreferrer" href="https://tinkersprojects.com/">https://tinkersprojects.com/</a><br>This WIFI barcode scanner is going to be used for my project dashboard, Projects and Parts. It will be used to keep track of parts and locations of parts. The parts will be placed in small containers with barcodes it and the barcode scanner can scan parts in/out of different locations and change the quantity.The ESP-12E barcode board could be made to work with most APIs that the ESP-12E can connect too.<br>parts list<br>– Barcode reader (<a target="_blank" rel="noopener noreferrer" href="https://www.aliexpress.com/item/Low-price-CCD-Barcode-Scan-engine-1D-ttl-rs232-usb-small-barcode-scanner-module/32847993312.html?spm=a2g0s.9042311.0.0.27424c4dTPX8qz">https://www.aliexpress.com/item/Low-price-CCD-Barcode-Scan-engine-1D-ttl-rs232-usb-small-barcode-scanner-module/32847993312.html?spm=a2g0s.9042311.0.0.27424c4dTPX8qz</a>)<br>– Projects and Parts or other API (
