MQ Plotter
The MQ Plotter is a machine that plots points on a grid. It is made from a 3D Printer Frame with different electronics and additional items
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
https://tinkersprojects.com/project/mq-plotter/
The MQ Plotter is a machine that plots points on a grid. It is made from a 3D Printer Frame and mechanism with different electronics and additional items. It uses a 12V DC power supply to power the system and motors and is complete with a 16 x 2 LCD and Encoder for the user interface. The electronics are based on a different but similar project. The ATMEGA328P Microcontroller has the Arduino UNO Bootloader installed on it. The USB at the back uses a CH340 chip which can be used to program the ATMEGA328P through the Arduino IDE.
Every point the machine plots on the grid, it moves upwards, pauses while the plot is active and then moves downwards. This process is repeated for every point. When the plot is active, a relay is activated. The relay output switch ports can be accessed from the back of the machine. Each point on the grid i
