RGB_LED Library
RGB LEDs are used everywhere, in many different products and devices. This Arduino library is to the control of RGB LED's
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
https://tinkersprojects.com/project/rgb_led-library/RGB LEDs are used everywhere, in many different products and devices. This Arduino library is to the control of RGB LED's colour and fading between colours. Almost every setting can be controlled through this library to control the RGB LEDs. The library contains preset colours and functions to make it easier to construct your RGB LED project.The library can be found: https://github.com/tinkersprojects/RGB_LEDVideo deminstrations: http://www.youtube.com/watch?feature=player_embedded&v=i7A1KCqNQHQ
