Arcade Claw Machine - Room Sized
A project log for Brushless Actuator (Arduino-Compatible)
Ardunio-Compatible M0/Zero/SAMD21 with FET Driver, MOSFETs, Absolute Magnetic Encoder, USB and RS485 comms. ~$US50
paul-gouldPaul Gould 08/07/2020 at 10:030 Comments
THe Brushless Actuators and GL5010 motors are used in Arcade Claw Machine - Room Sized project in the upper four corners of the room. Linked by RS485 communications. Limited to 2% Power.
https://hackaday.io/project/173988-arcade-claw-machine-room-sized
