I cleaned up the 1.2 version and created v1.2.1. The board is available at https://oshpark.com/shared_projects/B3IAiNyH and will be my last revision for now.
I created a new board that is slimmer and has SMD pad's instead of the drill pad's which gives it more flexibility. The board also comes with a status LED.
Parts
All parts available on DigiKey.com. I changed some components in this version!
- 1x ATTINY84 (Part ATTINY84A-SSURCT-ND)
- 1x Capacitor in 805 packaging (587-1304-1-ND)
- 1x Diode in SOD-123 packaging (MMSZ5231B-TP)
- 1x Blue LED in 805 packaging (150080BS75000)
- 1x Resistor in 805 packaging with value of 140ohms (Part RMCF0805FT140R)
Andy
