BitsyLED Board 1.2.1
A project log for BitsyLED
A minimal firmware and configurator to drive RGB LED's
andyAndy 04/30/2019 at 04:110 Comments
I cleaned up the 1.2 version and created v1.2.1. The board is available at https://oshpark.com/shared_projects/B3IAiNyH and will be my last revision for now.
I created a new board that is slimmer and has SMD pad's instead of the drill pad's which gives it more flexibility. The board also comes with a status LED.
Parts
All parts available on DigiKey.com. I changed some components in this version!
