Here is link on basic code for sending messages to The Things Network gateway. Data which you are sending are measured with BME280 sensor (temp/hum/pressure).
Code is based on LMIC library (LoRa MAC in C) and on LowPower library.
Code is made by Lex Bolkesteijn (github account: ph2lb).
https://github.com/ph2lb/LoRaWAN_TTN_Env_Node
Slaven Damjanovic
