VerilogCreator
VerilogCreator is a QtCreator based IDE for Verilog 05 and a subset of SystemVerilog
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
VerilogCreator is a QtCreator plugin. It turns QtCreator into a Verilog 2005 IDE. If you&#x2019;re interested in an open-source IDE which runs on all platforms and uses resources sparingly then you might have a look at it. Syntax checking/coloring and semantic code navigation/highlighting and code completion are supported; there are build configurations for Icarus, Verilator, Yosys and Tcl. Projects can be configured using a file format similar to qmake. <br><br>The recent version supports marker based code folding (MBCF) known from Emacs and Vim which let&#x2019;s you define arbitrary sections which can be collapsed and whose title is shown in the outline view for easy navigation. <br><br>Pre-built versions for Windows, Linux and macOS are available for download based on a minimal Qt Creator version called QtcVerilog.<br><br>See <a target="_blank" rel="noopener noreferrer" href="https://github.com/rochus-keller/VerilogCreator/blob/master/README.md">https://github.com/rochus-keller/Ver
