Happy new year and happy new firmwares for the LM80C Color Computers.
LM80C: new firmware release 3.16:
- Code revision to comply with the assembler SJASMPLUS
- Moved equates for BASIC workspace area into a separated file
- Serial buffer overrun revision
- Fixed a bug into the serial code: the incoming chars were print on screen even if the cursor was off (i.e., in indirect mode)
- Added key auto-repeat
- Added support for INSERT key to insert a space between text by moving the chars after the cursor position
- LIST now manage ending line number correctly, so that it won't list the line after the one passed as argument anymore
- BASIC support for serial channel B
- Preliminary support for external mass storage (stubs for ERASE, FILES, LOAD, SAVE commands)
- Mechanism to enable/disable the 512-byte buffer for mass storage I/O operations (by pressing SHIFT while logo is shown on startup) - AT THE MOMENT, DISABLED BY DEFAULT INTO CODE
LM80C 64K: new firmware release 1.01
LM80C 64K: new firmware release 1.02
Grab them at the official LM80C Github repo.
Leonardo Miliani
