Open Thermal Camera
Opensource, inexpensive, mobile thermal camera for use in electronics, home inspection, non-contact thermometer, heat distribution and more.
This project is based on the MLX90640 sensor to provide an opensource, hackable, customizable, mobile thermal camera. The camera has a resolution of 32x24 pixels. There are 2 hardware revisions, one with a Type-C connector and another with a reversible MicroUSB connector. The camera is used in conjunction with an Android application to display and take pictures of temperature distribution. All the necessary files are available on Github.
If you would like to receive project updates or be notified when the first batch will be available:
  • 1 × MLX90640 sensor Far infrared thermal sensor array, 32x24 resolution
  • 1 × STM32F042F6Px Microcontroller, footprint: TSSOP-20_4.4x6.5mm_P0.65mm
  • 1 × Resistor SMD 0805, 130R 1.15x1.40mm
  • 1 × Resistor SMD 0805, 10R 1.15x1.40mm
  • 1 × Capacitor SMD 0805, 2u2 .15x1.40mm
View all 16 components
  • Maker Faire Rome - European Edition
    TheMarpe10/18/2019 at 20:30 0 comments
    The Maker Faire in Rome has started on 18th October. We'll be at the event the whole weekend.
    https://2019.makerfairerome.eu/wp-content/uploads/2019/04/MF19_MAKER.png
    Anyone who is visiting or is thinking about visiting this years faire in Rome, feel free to swing by our booth and try out the Open Thermal Camera for yourself!
    We are presenting in Pavilion 7: Discover,  Booth - C4.
    Looking forward to your visit!
  • Node.js module for Open Thermal Camera
    Erik Kokalj09/21/2019 at 20:01 0 comments
    We have created a Node.js module (otc) that supports all available interface calls. On top of that, a demo cross-platform desktop app is in the making! Electron uses node.js' runtime therefore we used the mentioned module to create a simple cross-platform app. It was tested with WIn10 and RPI3 (Raspberrian). OTC is connected to the computer/RPI with a USB 3.1 Type C Female To USB 3.0 Male Connector. The electron app is already available on github.
    In the future we are planning to create a module for Python as well, which will support all interface calls.
    Next stop: People counter!
    Electron demo app run on RPI. On the image there's me, with a hand on my head.
  • Hardware redesign
    TheMarpe09/14/2019 at 18:57 1 comment
    Open Thermal Camera went through a slight redesign. The hardware is now unified for both Type-C and MicroUSB version. The housing can accept either of the PCB variants.
    (Right: Type-C variant, Left: back view of MicroUSB variant)
    With this step the hardware part is coming to an end and we'll start with improving the application side even further.
  • Tool for heat inserts
    TheMarpe09/01/2019 at 08:08 0 comments
    For easier assembly and consistent results with heat inserts, I took an evening to create a heat insert tool for use with a Ersa soldering iron.
    It looks something like this
    It's made for M2.5 inserts, which are used in housing for our project.
    This helps with much nicer finish as tested on our prototype housing.
  • Building more prototypes
    TheMarpe05/23/2019 at 20:01 0 comments
    While preparing for the upcoming Mini Maker Faire in Italy, Trieste, we've build more prototypes for people to try out and give their opinion on it.
    Also if you are around or you consider coming to Mini Maker Faire in Trieste this week 25th and 26th of May, do stop at our booth with number M-94 and give our project a try :)
    On to the pictures:
    More sensors came from DigiKey.
    Our first microUSB PCB revision to be fully assembled.
    MicroUSB and Type-C prototypes.
  • Project presentation at Mini Maker Faire Ljubljana
    Erik Kokalj05/12/2019 at 09:37 0 comments
    Yesterday (11-May-2019) we presented our Open Thermal Camera at Mini Maker Faire in Ljubljana. Many were impressed with the project and gave us some interesting use case ideas, such as home insulation inspection, water leakage detection, observation of wildlife etc.
    - Out booth at MMF Ljubljana with the number M9
    We had a few gadgets with distinct thermal contrast, such as:
    • RaspberryPi 3B
    • Soldering iron
    • Faulty PCB where one component was shorted
    We had a great time presenting our project to other makers and DIY enthusiasts =)
  • Android application added to GitHub
    TheMarpe04/29/2019 at 15:04 0 comments
    Today I've created a repository for Android application on GitHub. There is quite some work to be done on application side but things are working well up to this point. In the following days we'll be working on a use case scenario of inspecting a PCB. Stay tuned!
    Link to application repository: https://github.com/openthermalcamera/Android-Application
View all 7 project logs
lalalandrus wrote 11/06/2019 at 00:17 point
Great project, I ordered the PCBs to make a few. I was wondering what the part number for the microUSB connector.
TheMarpe wrote 11/06/2019 at 09:05 point
Thanks Lalalandrus!
That's great to hear, if you'll need any help building it, don't hesitate to contact me.
Otherwise the connector is from a company called Edley Technology from China, but its very inaccessible to get via the ordinary means.
If you'd like to build the MicroUSB version and you need the connector, write me a private message here on hackaday.
lalalandrus wrote 11/06/2019 at 20:41 point
I will let you know. Too bad I got the boards ordered already before getting this information, I would have switched the footprint. Pictures when I your work duplicated.
Does your android app perform any interpolation? http://blog.dzl.dk/2019/06/08/compact-gaussian-interpolation-for-small-displays/
lalalandrus wrote 2 days ago point
:( i recieved the boards and 1.6mm is too thick for the connector you spec'd i didnt think to check that, the data sheet isnt that great and doesnt say how thick the board needs to be. after checking the connector model, the board needs to be 0.8mm?
Erik Kokalj wrote 2 days ago point
Yes, in settings you can turn on/off the bilinear interpolation. :)
Mike Szczys wrote 10/22/2019 at 15:56 point
It was awesome to see you at Rome Maker Faire this weekend. I got to try out the camera, it works great! I really like how the USB-C plug off to one side makes it look like the flash unit for a minature film camera ;-)
TheMarpe wrote 10/22/2019 at 23:54 point
Thanks Mike! Nice meeting you as well :)
That design was the "only reason" for the plug position haha :P
Hope to see you again on some event/faire :)
Martin
Preston wrote 09/20/2019 at 14:15 point
New to this style of thing, where I everyone buying the supplies to build this?
TheMarpe wrote 09/20/2019 at 20:24 point
Check out any of the following suppliers: Farnell, Digi-Key & Mouser
Using these suppliers you'll be able to source all needed things to build this.
In case you'd require any help, don't hesitate to write back.
Will also be updating some of the repositories soon, so look out for that as well.
Best regards, Martin
beamrx5 wrote 09/09/2019 at 01:22 point
would it be possible for this module to output in video format (ntsc/pal) and overlay this on a standard dvr camera?
TheMarpe wrote 09/09/2019 at 21:00 point
Hi beamrx5!
This module unfortunately doesn't support video output, but in the works is a library for support of Raspberry Pi and other SBCs with which you could then display the thermal data through any desired video output available.
fail572872916 wrote 05/16/2019 at 16:10 point
Man, I want to make an app that can receive mxl90640 data. It's in an array, but I can't handle pictures. What should I do about it?
In fact, I already have a frame of data, and I want to receive it from Bluetooth and display it on Androdi. I don't know how to deal with it so that it can be displayed. It's about image processing. I hope you can help me.
TheMarpe wrote 05/16/2019 at 17:59 point
Do you have the raw frame data from the MLX90640 sensor or do you already have an array of computed temperatures for each thermal pixel?
fail572872916 wrote 05/17/2019 at 05:12 point
I've got the raw data, which is an experimental function of my collaboration with my classmates. Because the level is limited, I might as well let him generate a picture.
TheMarpe wrote 05/17/2019 at 06:52 point
If you've got the raw frame data, then you also need EEPROM data and you can use the Melexis API to calculate individual pixel temperature. https://github.com/melexis/mlx90640-library
fail572872916 wrote 05/17/2019 at 07:19 point
I'm stuck in this place. Maybe I'm not technically competent.
T-T T-T
TheMarpe wrote 05/22/2019 at 10:07 point
I think it's best if you explain the problem in detail to me through DM. I'll take a look at your case and see if I may assist you
fail572872916 wrote 05/22/2019 at 13:01 point
What is DM?
TheMarpe wrote 05/22/2019 at 14:20 point
A direct message or private message here on Hackaday.io
Mike Szczys wrote 05/06/2019 at 19:47 point
Cool! I've seen thermal cameras used to find where insulation is missing in the walls of houses. I could see a smartphone add-on being used by contractors doing weatherization work, but the FLIR unit starts at around $200. Glad to see an open version in the works :-D
Erik Kokalj wrote 05/09/2019 at 08:54 point
We (me and TheMarpe) initially thought of using it as a cheap PCB heat inspection gadget, since we are both in HW field. I'm glad you like the project and gave us application idea (isulation inspection), we will try it out. We will soon post updates/demo on how to use it and how it performs in real-life applications :)
