Building more prototypes
A project log for Open Thermal Camera
Opensource, inexpensive, mobile thermal camera for use in electronics, home inspection, non-contact thermometer, heat distribution and more.
themarpeTheMarpe • 05/23/2019 at 20:01•0 Comments
While preparing for the upcoming Mini Maker Faire in Italy, Trieste, we've build more prototypes for people to try out and give their opinion on it.
Also if you are around or you consider coming to Mini Maker Faire in Trieste this week 25th and 26th of May, do stop at our booth with number M-94 and give our project a try :)
On to the pictures:
More sensors came from DigiKey.
Our first microUSB PCB revision to be fully assembled.
MicroUSB and Type-C prototypes.
