Making chips now...
A project log for Mini Lathe (Emco Compact 5) CNC Conversion
New cross slide, BLDC spindle motor, custom 32-bit grbl port, spindle sync, threading (G76), MPG controller+++
terje-ioTerje Io 05/10/2019 at 12:220 Comments
I have added two wizards to my GCode Sender to simplify testing.
Turning - for reducing stock diameter:
Threading:
The threading wizard is ported from a utility written by Stephan Brunker for Mach3 (from FreeBasic to C#). Wizards for facing and parting to be added. Lots of testing required as all this is dangerous stuff.
