I chose to build mine out of individual RGB LEDs as I had a lot of them left form a past project but you could use a LED strip to make this project a lot quicker. I started by collecting my LEDs and finding out how big I could make the matrix. I decided to make a 7x7 Matrix so I needed 49 LEDs.
I then got a thin piece of MDF and drew a 1 inch grid on it. I then drilled 5mm holes where I had marked it on the grid. I sanded the wood then painted one of the sides white. I then place all the LEDs into the grid. Now to connect all the LEDs together. I started by soldering a piece of wire to the first LEDs anode and then striping back a piece of wire then soldered it to the next LEDs anode. I repeated this for all the anodes then the three colours.
Once the Matrix is assembled I took apart an old LED strip controller and cut of the end where the LED strip would connect. I then soldered the wires to the correct pins of the first LED. I then soldered some wire to the positive and negative of the power jack of the controler and connected it to a barrel jack.
Enclosure
I then measured the matrix board and that determined that the inside dimeter of the box needed to be slightly smaller. Once I had all the measurements I chose a piece of pine that was 100mm wide and cut it on the table saw at a 45 degree angel to the correct length. Once I had all the pieced cut to size I used a router to cut two channels into the inside of the pieces.
I then got a piece of acrylic and sanded both sides of it to give it a opaque look. Once everything was ready I drilled small pilot holes into the ends of the pine boards and used screws to hold it together. Once I had 3 sides screwed together I slid the matrix in and the acrylic into the grooves.
Before screwing on the other side I drilled a hole for the power jack and for the IR receiver. I then hot glued the receiver and the power jack into place before screwing on the last side.
I then plugged in the controller and turned it on using the remote and tested it all worked.Acknowledgement
I thank LCSC Electronics for the partnership.
LCSC Electronics Is China's leading Electronic Components Distributor. LCSC sells a wide variety of high quality electronic components at low prices. With over 150, 000 parts in stock they should have the components you need for your next project. Sign up today and get $8 off on your first order
Website
Check out more of my other projects on my website.
Adam Redfern
STEAL-THIS-HARDWARE
Jan
Steve Pomeroy
