To convert the front wheels to electric, I first 3D printed adapters, which can be used to mount the motors on the plastic frame:
Together with the other part it looks like this:
Now it will just replace the original plastic steering system:
The original plastic part that holds everything together can still be used:
Also the steering is still done with the original 10mm bent steel rod:
Peter Pötzi
