The LEGO Technic system is well known, and has many readily available pieces to use in custom projects, for frames, cases, or other robotic parts. However, if you want to use a standard servo, or mount a pi in your project, the pieces don't quite match up.
This project is to reverse engineer and recreate the principal components of the LEGO Technic system in a 3D printable format. This way, custom pieces for mounting these critical components can be designed and printed, but remain compatible with off the shelf Technic pieces.
