Missions: the Sole of Mission St.
A Novel Method of User Input.
A real-time Gait Analyzer.
A Passive and Continuous body-weight Scale.
Public Chat
SmartShoe Insoles that provide 3 key Features:
1) A Novel Method of User Input.
From Accessibility to VR/AR/XR and everything in-between, our posture can provide a variety of inputs for a wide range of applications.
2) A real-time Gait Analyzer
Users can be alerted of improper posture immediately, rather than be notified by their doctor decades later when it's too late.
3) A Passive and Continuous body-weight Scale
Our weight fluctuates throughout the day, including vertical spikes as we eat, drink, & use the restroom. However, our weight slowly decreases as we exhale carbon dioxide, which can be used to detect our metabolism fluctuation by noting the slope of the decline. We could also deduce hydration by comparing fluid intake and output, notifying users if they're dehydrated or retaining more water than usual.
We plan to use a Web Technology-based Software Stack, including:
Thanks to Kevin McCurdy for providing an awesome demo!
Next Steps:
  1. Design a PCB small enough to fit inside the enclosure that contains the following:
  2. Field test the insoles to figure out the most optimal pressure sensor distribution
  3. Setup decentralized storage solution to enable users to generate, share, and sell data
  4. Experiment with machine learning models to extract posture, gait, and weight features
  5. Redesign insole flexible PCB and enclosure with new pressure distribution and integration of PCB
The LiPo Charge Controller allows a microUSB cable to both power and charge the Lithium Polymer battery.
Portable Network Graphics (PNG) - 40.94 kB - 06/15/2019 at 23:00
Preview
Download
Missions Smart Insole Male Connector array used to connect to the female header connector on the Flexible PCB Insole.
Portable Network Graphics (PNG) - 81.72 kB - 06/15/2019 at 22:59
Preview
Download
A power and filtering module for ensuring that the Missions Smart Insole PCB can be powered by either microUSB or by a 3.7/4.2V Lithium Polymer battery.
Portable Network Graphics (PNG) - 53.61 kB - 06/15/2019 at 22:59
Preview
Download
The current design for the Missions PCB layout.
Portable Network Graphics (PNG) - 472.76 kB - 06/15/2019 at 22:59
Preview
Download
A USB to Serial Converter used to send data between a microUSB to the ESP32 VROOM microcontroller.
Portable Network Graphics (PNG) - 107.87 kB - 06/15/2019 at 22:59
Preview
Download
View all 22 files
  • 2 × ESP32 VROOM Module An ESP32 microcontroller that has both bluetooth and wifi capabilities as well as several GPIO pins.
  • 32 × 10K 0402 Resistor Pulldown resistors to decrease pressure sensor sensitivity (to approximate user's foot pressure and movement)
  • 2 × 3.7/4.2V LiPo Battery A battery to power the ESP32 chip
  • 2 × 1x18 Male Pin Header Connector A male pin connector array used to connect the Missions PCB to the Flexible PCB Insole.
  • 2 × MPU6050 6-Axis Accelerometer/Gyroscope An accelerometer/gyroscope module to track the user's foot position and orientation.
View all 10 components
View all 91 project logs
Talib Khurshid wrote 06/24/2019 at 01:39 point
Wow!
I'm actually working on similar project in Japan.
I'm total noob in this field and facing so many difficulties, it will be great to learn from you guys here and apply in my project !!
Looking forward to see development in this project.
Umar Qattan wrote 06/29/2019 at 03:23 point
Thanks!
iarakis wrote 05/09/2019 at 06:23 point
Great project. I would be glad to join the team for hardware or firmware engineering.
Umar Qattan wrote 05/09/2019 at 20:26 point
@iarakis that would be incredible! I'll be sure to add you.
artgodwin wrote 05/08/2019 at 23:06 point
I'm looking at doing it. But I'm sure all help is gratefully received.
phantomchips wrote 05/08/2019 at 22:17 point
This is a super interesting project.  Looking forward to seeing the updates.  Did you find someone to help with the pcb?
Umar Qattan wrote 05/08/2019 at 23:15 point
@artgodwin has just followed us and has been super active in helping us out so far!
Umar Qattan wrote 05/09/2019 at 02:29 point
Although we'd appreciate all the help we can get!
artgodwin wrote 05/08/2019 at 21:20 point
I found a few with the same name on that site, but they don't seem to match either. Looks like it generates them on request. Could you include the one it gave you with the files, please ?
Umar Qattan wrote 05/08/2019 at 21:36 point
Here's another link to the exact footprint library to add to your KiCAD editor https://www.snapeda.com/parts/ESP32-DEVKITC-32D/Espressif%20Systems/view-part/
artgodwin wrote 05/08/2019 at 20:08 point
What library have you used for the ESP32-WROOM ? It's not in my standard kicad libraries and the additional one I found at https://hackaday.io/project/13483-esp32-kicad-library doesn't fit your schematic
edit : there is an ESP32 in the kicad libraries, it's in the RF_Module library. But it's very different from the hole in the schematic.
Umar Qattan wrote 05/08/2019 at 21:01 point
marblypup wrote 05/08/2019 at 17:13 point
Interesting! I'm currently (very slowly) making a walking robot with load cells for toes!
dvalenzuela3 wrote 05/08/2019 at 16:19 point
Do you have the video of the presentation of one of the pictures?
Umar Qattan wrote 05/08/2019 at 17:45 point
videos can be found in the starred links - we've included "(VIDEO)" in the titles for clarity
stefane.lemay wrote 05/08/2019 at 16:14 point
Which Pressure Sensors have you used?  It is not listed in the Components...
Umar Qattan wrote 05/08/2019 at 17:49 point
They're resistive pressure sensors - we've included them in the "Components" section (thanks for pointing that out!)
