The LiPo Charge Controller allows a microUSB cable to both power and charge the Lithium Polymer battery.
Portable Network Graphics (PNG) - 40.94 kB - 06/15/2019 at 23:00
Preview
Download
Missions Smart Insole Male Connector array used to connect to the female header connector on the Flexible PCB Insole.
Portable Network Graphics (PNG) - 81.72 kB - 06/15/2019 at 22:59
Preview
Download
A power and filtering module for ensuring that the Missions Smart Insole PCB can be powered by either microUSB or by a 3.7/4.2V Lithium Polymer battery.
Portable Network Graphics (PNG) - 53.61 kB - 06/15/2019 at 22:59
Preview
Download
The current design for the Missions PCB layout.
Portable Network Graphics (PNG) - 472.76 kB - 06/15/2019 at 22:59
Preview
Download
A USB to Serial Converter used to send data between a microUSB to the ESP32 VROOM microcontroller.
Portable Network Graphics (PNG) - 107.87 kB - 06/15/2019 at 22:59
Preview
Download
The ESP32 VROOM microcontroller has built in Wifi and Bluetooth capabilities that fans out many GPIOs for reading sensor values or configuring for I2C to interface with an IMU or Haptics controllers.
Portable Network Graphics (PNG) - 92.26 kB - 06/15/2019 at 22:59
Preview
Download
The MPU6050 Module is a 6-axis gyroscope/accelerometer I2C device used for detecting a user's activity through foot articulation.
Portable Network Graphics (PNG) - 64.85 kB - 06/15/2019 at 22:59
Preview
Download
Missions_v1.brd
Missions Smart Shoe Insole board layout.
Designed by Jonathan Hurwitz
(https://www.linkedin.com/in/jdhurwitz/)
brd - 167.15 kB - 06/15/2019 at 22:58
Download
Missions_v1.sch
Missions Smart Shoe Insole Schematic.
sch - 517.08 kB - 06/15/2019 at 22:58
See BOM
Download
Top_Mission_Enclosure.stl
The top 3D Printed enclosure for the flexible PCB.
Designed and 3D-Printed by Austin Kahn (https://www.linkedin.com/in/austinkahn/), Co-founder and CPO of Atmos (https://discord.gg/JsdnX76)
Standard Tesselated Geometry - 246.76 kB - 05/28/2019 at 20:40
Download
Bottom_Mission_Enclosure.stl
The bottom 3D Printed enclosure for the flexible PCB.
Standard Tesselated Geometry - 165.22 kB - 05/28/2019 at 20:40
Download
Xact FSR Material Description.pdf
A description of the Mylar material used to smoothen the pressure applied to any individual FSR on the Flexible PCB Insole
Adobe Portable Document Format - 387.46 kB - 05/28/2019 at 04:51
Preview
Download
A schematic diagram of the Flexible PCB Insole
Portable Network Graphics (PNG) - 201.24 kB - 05/28/2019 at 04:48
Preview
Download
Sensitronics FSR Datasheet.pdf
A data sheet detailing the physics behind the FSR (Force Sensitive Resistor) material used on the Flexible PCB Insole
Adobe Portable Document Format - 865.48 kB - 05/28/2019 at 04:47
Preview
Download
ESP-WROOM-32_(16MB) Library.zip
Symbol and Footprint Libraries for the ESP32 WROOM-32 Bluetooth/Wifi Enabled component (KiCAD or EAGLE compatible)
Zip Archive - 571.73 kB - 05/12/2019 at 03:08
Download
BM24-20DP_2-0 Library.zip
Symbol and Footprint Libraries for the DM24-20DP FPC Connector component (KiCAD or EAGLE compatible)
Zip Archive - 549.44 kB - 05/12/2019 at 03:06
Download
MPU6050 Library.zip
Symbol and Footprint Libraries for the MPU6050 Gyroscope/Accelerometer component (KiCAD or EAGLE compatible)
Zip Archive - 624.83 kB - 05/12/2019 at 03:02
Download
DRV2605L Library.zip
Symbol and Footprint Libraries for the DRV2605L Haptics Controller component (KiCAD or EAGLE compatible)
Zip Archive - 643.58 kB - 05/12/2019 at 03:00
Download
DRV2605L Datasheet.pdf
DRV2605L Haptics Driver Datasheet
Adobe Portable Document Format - 2.94 MB - 05/12/2019 at 02:56
Preview
Download
MPU6050 Datasheet.pdf
MPU6050 IMU (Accelerometer/Gyroscope) Datasheet
Adobe Portable Document Format - 1.42 MB - 05/12/2019 at 02:56
Preview
Download
ESP32 WROOM Datasheet.pdf
ESP32 WROOM32 Datasheet
Adobe Portable Document Format - 509.77 kB - 05/12/2019 at 02:56
Preview
Download
LiPo Charge Controller Schematic.pdf
A schematic detailing a layout for a LiPo Battery Charge Controller with a micro USB input.
Adobe Portable Document Format - 39.24 kB - 05/12/2019 at 02:56
Preview
Download
