Analog Watch is working
A project log for (BCD)WristWatch
It all started with the idea of a PCB which could display the time in BCD code....
sulkithsulkith 10/05/2020 at 16:130 Comments
The analog watch is finally Working :-)
Some problems with the Locking of the Ports were causing the BMA Sensor to not work.
The solution was to change the Initialization order as follows:
Now basic functionality is given. So it is time to test it.
