FPV Ball
What a stupid idea... throwing a fpv camera.
I wanted to throw my fpv camera through the air and get sick by watching the video. No, I really don't know why, but I did it anyways.
Ball vorne 6.stl
Front part.
Standard Tesselated Geometry - 1018.93 kB - 05/03/2019 at 20:55
Download
Ball hinten 6.stl
Back part.
Standard Tesselated Geometry - 770.59 kB - 05/03/2019 at 20:55
Download
  • 1 × Small FPV Camera off Amazon
  • 1 × FPV Goggles
  • 1 × Tennis ball
  • 1 × 3d printed parts
  • Third build
    Max-Felix Müller05/08/2019 at 15:04 0 comments
    I've gone ahead and printed the latest design of the fpv ball.
    Now the Field of view is nearly completly clear of the walls. Additionally I fixed all the small tolerance / clearance issues I had. The print took about 1h on coarse settings.
    Soon I will record some footage and upload it.
  • Second build
    Max-Felix Müller05/03/2019 at 21:02 0 comments
    Now I want to desing a 3d printable version of the inside of the ball.
    This would fix the camera position.
    Also it looks cool with the green filament I'm using.
  • First test
    Max-Felix Müller05/03/2019 at 21:01 0 comments
    The image quality is really bad.
    Partly because the camera brightens up the image because it sees a border all around (camera cutout too small), but mainly because the antenna is just in very weird angels when thrown so the reception is extremly bad most of the time.
  • First setup
    Max-Felix Müller05/03/2019 at 21:00 0 comments
    I cut open a tennis ball and put in the fpv camera. To fix it's postition and dampen the impact when catching (do not let it hit the ground) I put some foam around it.
    On the back side of the ball I cut a slit to put in and out the battery.
View all 4 project logs
  • 1
    Title
    1. Put in the fpv camera
    2. Glue on the back with hot glue so that it could be removed if neccessary
    3. (Optional: Cut open a tennis ball and put it in for added protection)
    4. Connect battery
    5. Throw
View all instructions
Mike Szczys wrote 05/06/2019 at 21:06 point
Ooooh, cool! Please post the photos (even the bad ones).
I think this will be a really cool thing but I suspect the spinning of the ball will be a problem. Perhaps it'll just make some trippy images ;-)
morgan wrote 05/06/2019 at 21:33 point
A streamer tail might keep the camera oriented forward
Max-Felix Müller wrote 05/07/2019 at 12:04 point
I do have a small recorder to record live footage. I will upload some at the end of the week because I'm currently busy studying for my exams.
Blo0dygeek wrote 05/06/2019 at 08:53 point
lol. It's ain't stupid, kinda looking forward to more details.
