First setup
A project log for FPV Ball
What a stupid idea... throwing a fpv camera.
Max-Felix MüllerMax-Felix Müller 05/03/2019 at 21:000 Comments
I cut open a tennis ball and put in the fpv camera. To fix it's postition and dampen the impact when catching (do not let it hit the ground) I put some foam around it.
On the back side of the ball I cut a slit to put in and out the battery.
