Hackaday.io Hackaday.io
Sign up Log in
Ideas for CNC machines - make it simple
For the 2019 HackadayPrize I'd like to demonstrate how to implement a couple of simple ideas in your future CNC projects.
norbert-heinzNorbert Heinz
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
  • Hackaday Prize 2019
View Gallery
947
0
10
12
Team (1)
  • norbert-heinzNorbert Heinz
Join this project's team
  • HomoFaciens
MISC
ongoing project
CNC plotter 2019hackadayprize
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 05/04/2019 and last updated 7 years ago.
Description
After creating CNC routers composed of commonly available materials in previous HackadayPrize entries, I'd like to give you more ideas of how to create own computer controlled machines, address weak points in mechanics or electronics and do some coding to control your hardware. What ideas? Well, I don't know yet. I simply trust my inspiration and hope the Hackaday community will leave comments every now and then. So follow this project and read the log entries to see what's going on, here...
Project Logs
Collapse
  • DIY direct granules extruder, simple construction
    Norbert Heinz • 06/29/2019 at 08:07 • 0 comments
    I have added a DIY direct granules extruder to one of my 3D printers:
    The print head is as simple as I could think of, but maybe I can do it even simpler...
    Next question to answer is how to get the right sort of granules from the right sort of plastics.
    All infos on my pages:
    https://homofaciens.de/technics-machines-3D-printer-Granule-Extruder_en.htm
  • Matrix plotting with a 3D printer
    Norbert Heinz • 05/17/2019 at 15:45 • 0 comments
    A couple of more parts turned my plotter into a dot matrix printer. It's for sure no replacement for an inkjet, but another educational tool that visualizes the difference between vector and bitmap graphics. I am utilizing the filament extruder to speed up the movement of the pen.
    More on my pages:
    https://homofaciens.de/technics-machines-3D-printer-Zonestar-Printer_en.htm
  • Turning a 3D printer into a plotter with automatic pen changer
    Norbert Heinz • 05/04/2019 at 14:59 • 0 comments
    I have turned a 3D printer into a plotter with automatic pen changer:
    Up to four colours are picked automatically during plots. I have written a command line program in C to access the plotter through USB and a Perl script to convert Scalable Vector Graphics into Gcode commands. More on my pages:
    https://homofaciens.de/technics-machines-3D-printer-Zonestar-Plotter_en.htm
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The 2016 Hackaday Prize
The project idea is to design custom surgical instruments like retractors both in size or shape and 3d print them
Project Owner Contributor
Open Sourcing Surgery
leandroleandro
Usb phyton controlled heated bed for M3D 3d printer, making abs printing possible
Heated Bed for M3D 3d Printer
gorkyGorky
simple and small 3d printer with most of parts printed at home
protoBOT 3d printer
michal-wojciechowskiMichal Wojciechowski
The 2018 Hackaday Prize
The Automatic Infinite 3D Printer (i3D) gives anyone the power of a factory.
swaleh-owaisSwaleh Owais
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Ideas for CNC machines - make it simple", please tell us the reason.
Send message
Remove Member
