PI5USB30213A USB-C mux breakout
A project log for HDMI capture project
Capture uncompressed HDMI using ECP5 FPGA and USB 3.0 FIFO
konrad-beckmannKonrad Beckmann 05/29/2019 at 22:203 Comments
Made a breakout board for the PI5USB30213A USB-C mux since I'm a little bit worried I might mess up the wiring for it. Might be useful for future projects as well.
Schematic [pdf]
Repository
Konrad Beckmann wrote 06/13/2019 at 20:51 point
Built and tested one board now. The RX and TX pairs are swapped on the USB-A side. The Enable pin should be tied to GND to actually enable the chip (not left floating as I thought). The connector seems to be glitching, but maybe I just failed to solder it properly.
Konrad Beckmann wrote 05/30/2019 at 08:41 point
https://www.cui.com/product/resource/uj31-ch-smt.pdf
Note the PCB edge in the drawing. It's quite a bit away from the holes.
https://allg.one/22jQ
arturo182 wrote 05/30/2019 at 08:26 point
Have you verified that USB footprint in relation to PCB edge? It seems really far, hope you can plug in a cable. Maybe try to find a 3d model.
Also, round them corners!
