Features (for now):
- 3.3v to 26v (+/- 12v) Supply voltage single supply or not
- 145 MHz GBWP, 7nV/Sqrt(Hz), low bias, etc (see opamp datasheet)
- User selectable gain from 1 to 9000
- can be configured as a current to voltage converter (transconductance amplifier) with gains of 10, 100 and 1000
- can be configured as a inverting or non-inverting amp
- AC/DC input selection
- footprints for BNC, SMA and header pins for the input and output.
Any other ideas are welcome.
NandFarm Creator
Bud Bennett
James Wilson
The Big One
The main thing I'd like to see would be get rid of the BNC connectors and use screw terminal connectors so you can hook up whatever wires you want. Using a BNC connector would restrict the usefulness of something like this for me anyways
