Credit card blocker
Turn off your credit card and experience true freedom.
If you are like me and most of your spendings after 2PM are not really useful, you may want to turn off your credit card systematically.
Robert wrote 10/14/2024 at 14:17 • point
I can totally relate to that! A good way to manage unnecessary spending is to use a virtual card service like https://linkpay.io/. With it, you can easily generate temporary virtual cards that you can turn off anytime. This way, if you know that most of your spending happens after a certain time, you can just disable the card in advance and avoid those impulse purchases. It's a flexible solution that puts you in control of your finances, no matter the time of day!
