Next up: I want to create a waterfall showing the power distribution over the recorded bandwidth over time.
To do so, I save all the spectrums I calculate in one array. The it is as simple as putting that array in a file.
imagelist = []
for arr in image:
thislist = []
for dat in arr:
#dat = 10 * math.log10(dat)
thislist.append(mymap(dat, min_pow, max_pow, 0, 255))
imagelist.append(thislist)
largearray = np.array(imagelist, np.ubyte)
im = Image.fromarray(largearray, mode='L')
im.save("ichbineinwasserfall.bmp")
My main problem was, that I didn't set the data type of the numpy array so the conversion with pillow into an image as a byte array failed.
![](https://cdn.hackaday.io/images/4262791557517305939.jpg)
This is the result for 94.7MHz. The spectrum is shown in a lot of other images I uploaded so I don't want to post it yet again.
By the way: I use 94.7 as center frequency mostly because there is a radio station near me so I have a good signal to practice with 24/7.
The next step is to combine the waterfall and the graph in one window.
